Which glue
Old Jan 3, 2013 | 02:11 AM
cwaynem's Avatar
cwaynem
Default Which glue
i am replacing the glass in my outside mirror on my 76. Any glue recommendations that will make it through a Texas summer? Gorilla glue?
Old Jan 3, 2013 | 07:54 AM
scottw's Avatar
scottw
http://forums.corvetteforum.com/c3-g...oday-pics.html
Here is a post on fixing/replacing mirrors. He used JB Weld.
Old Jan 3, 2013 | 08:29 AM
oldalaskaman's Avatar
oldalaskaman
I used 3M double stick tape last summer in case I needed to replace them ...again. it got to 114 without issues.
Old Jan 3, 2013 | 09:24 AM
redrdstr72's Avatar
redrdstr72
Here's another idea for you to consider.
I had complete success by applying a dab of clear silicone caulk/adhesive to the top of each corner boss in the chrome fixture, then pressing the mirror glass on and clamping (careful not to apply clamp directly to the glass) while the silicone cures.
I replaced glass once, removing repro glass from a repro mirror and gluing in a dated original with absolutely no complications. I removed the old glass by soaking the entire mirror head in lacquer thinner over night. The old glass lifted right out with no problems and no damage to chrome or glass.
Hope this helps.
Old Jan 3, 2013 | 11:21 AM
7T1vette's Avatar
7T1vette
The glue/adhesive for the mirror glass needs to be flexible to withstand a [seasonal] temperature difference of over 100*F; remember, it's glass attached to metal.
Use Permatex black RTV for that job. It will stay flexible and it will last. Also, when you glue it, you need to 'stage' the glass on something very flat...upside down...then place the mirror body upside-down on the glass. That way the glass is not distorted by the weight of the mirror body. It also won't be distorted by its own weight, if you were to try putting it together right-side up.
Old Jan 4, 2013 | 12:01 AM
Korevette's Avatar
Korevette
We used a solvent to clean up the old adhesive, a primer and then urethane to bond the glass/mirror to the fixture.
Styrofoam blocks on the glass/mirror face and a couple of wraps with masking tape around the fixture got the job done.
Old Jan 4, 2013 | 12:39 AM
vetteguy22's Avatar
vetteguy22
I have used silicone many times with good success.
To Which glue
