71 Tachometer quit working today
Old Jan 5, 2013 | 10:01 PM
norrisde's Avatar
norrisde
7th Gear
Default 71 Tachometer quit working today
Where do I start on troubleshooting this. It was working fine yesterday and today...nothing! What feeds the tach? Is it coming off of the distributor? Coil?
All original 350
Old Jan 5, 2013 | 10:21 PM
oldalaskaman's Avatar
oldalaskaman
make sure its plugged in
Old Jan 5, 2013 | 10:26 PM
7T1vette's Avatar
7T1vette
If your ignition system is still "stock" (as it came from the factory), the tach 'signal' is coming to the tachometer via a flexible cable...similar to the speedometer. There is a tach drive gear built into the distributor shaft; and the cable runs from there, through the firewall, and is connected to the tach gauge.
There are two failure modes that are most likely for this:
1.) the drive cable has failed and is shredded somewhere in the cable sheath, so that no rotational signal is reaching the tachometer;
2.) the teeth on that little brass cable drive gear (in the distributor) has lost it's teeth so that the cable is no longer rotating.
There are other possibilities, but those are the most likely causes.
Old Jan 5, 2013 | 10:27 PM
gcusmano74's Avatar
gcusmano74
1) check for a broken cable.
2) check the gearset inside the distributor, both the mainshaft and the cross shaft.
Old Jan 5, 2013 | 10:34 PM
norrisde's Avatar
norrisde
7th Gear
It is completely stock and original. Ahhh yes....I see the cable. I will pull it and see if it is broken.
Best source for a replacement?
Is there anyway to convert it to electronic?
Old Jan 5, 2013 | 10:43 PM
mrvette's Avatar
mrvette
Yeh, you need a tach from '75-77 vette, bolt in swap, and run a wire from the points side of the coil to the tach input....
unless you want a HEI upgrade....totally another topic....
You may well need a 'tach filter' too....yet another topic....
Old Jan 5, 2013 | 10:49 PM
norrisde's Avatar
norrisde
7th Gear
I just pulled the cable from the distributor and spun it with a drill....tach portion works so I assume that the gear set in the distributor is stripped?
I assume I must pull the distributor for this repair?
Old Jan 5, 2013 | 11:10 PM
norrisde's Avatar
norrisde
7th Gear
Cable looks fine, how do I replace the gear set?
Old Jan 5, 2013 | 11:12 PM
7T1vette's Avatar
7T1vette
'Fraid so. Some gear teeth are not meshing...usually because they are no longer there. If you have enough access, you can remove the cable from the distributor, then use some straight metal piece to act like a BIG screwdriver and remove the outer gear retainer. Then remove the driven gear and have a look inside with a penlight.
Another possibility (if you don't find damage to the gear teeth) is that the driven gear has "eaten" down into the body of the distributor so that the gear teeth are no longer engaged with the drive [worm] gear on the distributor shaft. To repair this condition, you need to fashion a plug of a particular size and thickness and assemble it into the distributor body to realign those gears. If that is your problem, make another post to this thread and we can direct you to helpful advice on how to repair it. Of course, you can always go buy another distributor; but repairing yours for little expense seems a better idea.
Old Jan 5, 2013 | 11:20 PM
norrisde's Avatar
norrisde
7th Gear
I see that Wilcox has a gear set for about $30....that looks like the way to go!
Old Jan 6, 2013 | 12:31 AM
7T1vette's Avatar
7T1vette
Not until you determine that it IS a gear-related problem. You need to open up the dizzy to find the fault. Then, you can decide how to proceed and what you need to purchase.
Old Jan 6, 2013 | 08:43 AM
yyz1970's Avatar
yyz1970
If the tach drive gear is toast the distributor shaft gear is also likely toast
You will have to rebuild the distributor
Old Jan 6, 2013 | 09:17 AM
Big Block Dave's Avatar
Big Block Dave
Check to make sure that the end of the cable is square and that if there is any sort of plastic sheath that caps it is in good shape. If this sheath is broken or rounded at the point that the cable enters, or where it enters the distributor, this can also be a source of the problem.
Also, with the car running, you can stick your finger over the recepticle on the distributor and feel if it is moving. Better to cover all bases then to fix one trouble spot but not eliminate the problem
To 71 Tachometer quit working today
