A6 compressor
Old Jan 8, 2013 | 02:00 PM
rep69's Avatar
rep69
Default A6 compressor
I have a 1969 427 with the original A6 A/C compressor. It finally blew a seal and I hade it replaced with an aftermarket compressor. I am still using r12 in the system. I have the original A6 compressor. My question is should I have the original one rebuilt and reinstall or buy a new A6. . I would like to keep the car original. Any suggestions ?
Old Jan 8, 2013 | 02:08 PM
MelWff's Avatar
MelWff
Thats your call, original, correct date, would mean the original compressor.
Old Jan 8, 2013 | 02:40 PM
7T1vette's Avatar
7T1vette
I'd suggest that you just rebuild the original unit (if it is not damaged internally). You know that it was working properly; you can't be sure of that anymore with a "new" one...
Old Jan 8, 2013 | 03:31 PM
rep69's Avatar
rep69
The unit appears to be in good shape. No outside damage. I believe there is a rebuild kit with seals and o rings? I still have r12 to go back in the system.
Old Jan 8, 2013 | 03:37 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Is the broken one your original? If it's original and you are leaning toward having the car judged, you should consider having the original rebuilt.
To A6 compressor
