Valve Adjustment!!!
Second note. What I was asking originally was do I need to retighten the valves after rotating motor a few times. The rockers seem to be slightly looser than when I originally tightened?
Since some people want to know how to set "solids", rotate the engine until the cam is at base circle for the cylinder you're working on, and adjust accordingly. Since I haven't adjusted a solid cam since the early 70s, I may not be totally accurate, but I seem to recall the lash was 0.028" on the intakes, and 0.032 on the exhausts....
Better yet, consult a shop manual for the specifics, which escape me for the moment, but if you have both #1 and #6 clylinders on TDC, you can adjust half the valves, and rotate the engine one turn clockwise (as facing the engine) and adjust the other half....
Try posts 7 and 8 for openers....
Solid lifters need "lash" (mechanical clearance to allow for heat expansion in the valve train), while hydraulics need "pre-load", for essentially the same reason, but in a different manner. These adjustments are completely different, and unless you initially specify what type of lifter you're dealing with, the discussion loses meaning, and/or can send the OP off in an incorrect direction.
lars
