engine ice
Old Jan 9, 2013 | 11:26 PM
George Ries's Avatar
George Ries
Default engine ice
Has anybody ever used engine ice in the radiators
Old Jan 10, 2013 | 12:15 AM
Peterbuilt's Avatar
Peterbuilt
As a auto tech you should know that if your cooling system is up to par you don't need anything else besides the correct mix of coolant.
Old Jan 10, 2013 | 12:56 AM
George Ries
will it says it will lower engine temp and i have used it in my 2001 cr500 dirt bike and it works well in that was just wondering if anybody tried it in a c3 vette it says it will work in car as well since these cars like to run on the hot side
Old Jan 10, 2013 | 01:01 AM
cv67's Avatar
cv67
St. Jude Donor '05
Tried a few products like that and found the money was better spent on lunch. All you need is a good cooling system/water +coolant. If you still have an issue something needs attention
Old Jan 10, 2013 | 01:04 AM
George Ries
thats what i thought waste of money my vette runs cool as can be
Old Jan 10, 2013 | 08:11 AM
garygnu's Avatar
garygnu
I use wetter water and diststilled water .
Old Jan 10, 2013 | 08:18 AM
drwet's Avatar
drwet
I have also used it in the bikes with good results. If the cooling system in your Vette is borderline I would expect it would work there as well. I your system works well with a regular coolant blend, I would stick with that.
Old Jan 10, 2013 | 08:19 AM
MrJlr's Avatar
MrJlr
I tried a product like that once.....didn't make a difference.
Dewitts rad and duel fans.....THAT made a difference!
Old Jan 10, 2013 | 08:36 AM
Matt Gruber's Avatar
Matt Gruber
on my 61 i put in a rad from a 4cyl VW. it weighs 4.5#. holds 40 ounces.
eliminated engine fan. have manual elec fans.
3 years and it works well.
no snake oil added.
my 72 has a GIGANTIC rad by comparison
Old Jan 11, 2013 | 02:15 AM
Vette5.5's Avatar
Vette5.5
Engine Ice and Redline water wetter are the same thing. A surface surfactent that effectively increases water to metal surface contact. Works best with no anti-freeze in race cars, but maybe some benifit in daily drivers. Wouldn't bet on seeing much difference though.
Old Jan 11, 2013 | 02:32 AM
d555's Avatar
d555
x2 on this, works ok with water....ineffective with glycol based coolants. Save your money!
Dave
Old Jan 12, 2013 | 11:47 AM
MrJlr's Avatar
MrJlr
Dewitts is having a sale right now!
Old Jan 12, 2013 | 11:53 AM
Mike Ward's Avatar
Mike Ward
Dave
That's cause regular coolant already contains the same stuff as water wetter or 'ice'. More is not better.
Old Jan 12, 2013 | 03:41 PM
d555's Avatar
d555
Yes, it's used for cars that run distilled water only in their cooling systems. Replaces that which is lost when not running a standard coolant.
but....if you take your car to the track and race it and dump YOUR coolant on THERE track with anti-freeze. You will find out just how pissed off others on site can get. High horsepower cars and anti-freeze do not mix. Ethylene Glycol is not readily burnt off like straight water.
...very, very unsafe condition and that lane will not come back that day/night. Track prep is critical to High HP cars and they may not let you race on THERE track again. And most don't forget!
So... if this isn't you than just run clean 50/50 EG/h2o mix.
.o2c
Dave
To engine ice
