Won't start
Old Jan 12, 2013 | 03:45 AM
redvetteman81's Avatar
redvetteman81
Default Won't start
Put in battery after car would't start, does this sound like the starter? There isn't even a click and won't turn over.
Old Jan 12, 2013 | 06:50 AM
scottw's Avatar
scottw
Starter solenoid maybe. Are you getting power to the starter? That would be my first check. Did you have any issues prior to this or did you go out one day and it didn't work so you bought a new battery and replaced it?
Old Jan 12, 2013 | 08:49 AM
speedreed8's Avatar
speedreed8
check the ground connection under the car on the frame, and try putting it in neutral, or move the shifter back and forth. it may be the neutral safety switch.
Old Jan 12, 2013 | 11:17 AM
redvetteman81
No it just wouldn't start,so I replace the battery, it tested bad
Old Jan 12, 2013 | 12:12 PM
scottw's Avatar
scottw
Get a voltmeter and see if you have power to your starter. If not, check your grounds and fuseable link going to the starter.
Old Jan 12, 2013 | 03:24 PM
redvetteman81
get a voltmeter and see if you have power to your starter. If not, check your grounds and fuseable link going to the starter.
thanks scott
Old Jan 12, 2013 | 09:22 PM
redvetteman81
I tapped the starter with a hammer but it won't engage all the way, replaced the starter
Old Jan 13, 2013 | 07:00 AM
scottw's Avatar
scottw
Why are you hitting your starter with a hammer?
I'm assuming you have power to the starter and it is not engaging the flywheel when you say it won't "engage all the way," correct?
Since you replaced the starter, does it work now? If not, think you need to go through some troubleshooting processes and not just replace parts. Could get very expensive.
Old Jan 18, 2013 | 11:22 AM
redvetteman81
the bendix was stuck, so I replaced the starter, starts on a dime now.
Old Jan 18, 2013 | 05:54 PM
Drew's Avatar
Drew
I just went through the same thing. I thought I had a bad battery, but that wasn't it. I pulled out the original starter and had it rebuilt......No problems anymore...
To Won't start
