I think Calipers look good painted red. I also like them as original non painted. I'm about to put rebuilt calipers on soon and I bought both clear and red high temp paint and I'll choose one or the other.. Stoopid question: if I don't at least spray the clear on, then the calipers go rusty right? Whats the best way to prep (clean) store-bought calipers? I was gonna spray them with brake cleaner. Will that be enough? Am I being dumb or is it reasonable to paint a part in clear so that it doesn't get rusty. Do people do that?
If you have stock wheels, like I do, it doesn't make a lot of sense to paint red because you can't see them. If you have custom wheels, I think red calps look great.
I did not paint mine or put anything on them. I just hooked them up and installed. I also went with new brake hoses while I had the calps off.
Not stupid at all. Brake cleaner or acetone is effective at removing any shipping oil. Sometimes even a light rub down with a soaked rag.
You can clear the bare metal. The only possible problem is clears have a tendency to "yellow" with heat. But, it would keep it from rusting. You could also paint them a "cast" color, or silver.
Powder coating is always the ultimate way to go. Most durable and unlimited color choices, including all your casts, bare metals, etc.
I recently set up a powder coat shop at my house for my resto-mod and will be doing my calipers soon. Might even start doing some powder coating as a side gig.
If you have bare (un-assembled) calipers, the BEST way to coat them is to clean the outer surfaces well, then shoot them with a coat or two of VHT cast-iron colored paint. When dry, bake them in a toaster oven according to instructions on the can. This will turn them into a ceramic-like paint that is impervious to environmental conditions and will withstand heat of heavy braking use. They will continue to look the same for many years and not rust.
I used Duplicolor Cast Grey on mine. They are still looking great after 4 years of driving
before i Installed my new Rotors I masked them off and sprayed the non contact areas with silver Caliper paint to prevent rusting. They still look great after 4 years
I really like that look. Nice and clean!
As an aside, is that the stock routing for the hard brake line at the caliper? I've got a stock style rear sway bar link and the brake line doesn't seem to fit right on either side.
I believe it is. I purchased the complete Stainless brake and fuel line kit from Corvette Central
G2 caliper paint is by far the best stuff to use - far better than any spray can paint. It is a real 2-part coating that you brush on. It is self-leveling, so no brush marks remain after. It is the closest thing in appearance to powder coat that I have used.
Here is a tip: whatever product you decide to use, some time spent smoothing the surface of the caliper will result in a far better looking job. The cast iron calipers are fairly rough, and that roughness is always visable though the paint. Here is a pic of one of my front calipers; a lot of people think they are an aftermarket aluminum caliper because of the way they look!
Thanks for the responses. Stoopid question: If baking hardens the paint And Hot sun helps the paint harden (Maybe), then shouldn't I just paint them, put them on and go for a ride. Wouldn't the heat bake the paint too?
I'm diggin the cast grey paint....
Unless you are going to run a complete road race (a couple of hours at racing speed), your brake calipers will never get hot enough to bake VHT paint (or any other temp-cured, ceramic paint).
Just bake the darned things and be done with it. You are approaching the mode of "analysis paralysis".
