Inside mirror replacement
Old Jan 16, 2013 | 09:32 PM
1955pirate's Avatar
1955pirate
Default Inside mirror replacement
The ball arm on my '69 coupe inside mirror is broken. It looks as though to replace the ball arm the header must be removed. Right?
Old Jan 16, 2013 | 10:07 PM
'75's Avatar
'75
If it's like my 75, there is a soft cover over the mirror bracket and then just a screw to remove the retainer.
http://www.zip-corvette.com/ProductD...GR-SR&CTitle=&
Old Jan 17, 2013 | 03:20 PM
Alan 71's Avatar
Alan 71
Hi 55p,
I believe '75 is right.
There's a soft vinyl cover over the mirror mount. The cover has 'tabs' that slip under the header trim to hold it in place.
When you gently remove the cover you'll see the mirror mount.
If you can't get the 'tabs' loose you'll need to remove the interior header trim. This isn't too bad a job since all the screws are visible. You will need to unscrew the mounts for the sun visors though.
Good Luck!
Regards,
Alan
To Inside mirror replacement
