what do I have
Old Jan 25, 2013 | 10:39 AM
STANZACUSTOMS's Avatar
STANZACUSTOMS
5th Gear
Default what do I have
i bought a 69 vette with no motor or trany. i would like to restor it to originail. it does have a rear sway bar so i think it might have been a bb.i found the builders info engine code is ms. trany code is c. rear end code is fc. can anybody tell me what I have? and it has larger brakes than my other 69. was this after market
Old Jan 25, 2013 | 11:05 AM
7T1vette's Avatar
7T1vette
Where does the 'redline' shift point on the tachometer start? That will pretty well determine what engine came in the car.
Old Jan 25, 2013 | 11:26 AM
my 76 ray's Avatar
my 76 ray
If you don't have the original engine and tranny then the car will never be "original". I would just get the engine and tranny that performs the way I want it.
Old Jan 25, 2013 | 11:34 AM
STANZACUSTOMS
5th Gear
Ok let me reword that. I would like to restore it with the same engine and trany it came with.
Old Jan 25, 2013 | 11:36 AM
bashcraft's Avatar
bashcraft
They only came with one size of brakes, so...
Old Jan 25, 2013 | 11:37 AM
7T1vette's Avatar
7T1vette
And the redline on the tach starts at.......????
Old Jan 25, 2013 | 11:51 AM
Hammerhead Fred's Avatar
Hammerhead Fred
Where are you getting those codes?
69 MS, C, FC; would be a COPO 427, M22, w 4.56
and J56 heavy duty brakes were an option in 1969
Old Jan 25, 2013 | 11:56 AM
STANZACUSTOMS
5th Gear
The yellow begines at 6300 and red lines at 6500
Old Jan 25, 2013 | 12:04 PM
STANZACUSTOMS
5th Gear
I got those codes off of a tag on the tank plus other info that came with the car. The car is a two owner. I got it as a stollen recovery stripped car.
Old Jan 25, 2013 | 12:06 PM
STANZACUSTOMS
5th Gear
Thanks do you know which 427. I can't find info on ms engine code
Old Jan 25, 2013 | 12:26 PM
champs65's Avatar
champs65
MS looks like a 69 corvette 427 Last column reads "questionable" though...idk what that might mean...maybe related to horsepower, carburation, or transmission combos with that block?
http://www.nastyz28.com/gm-chevy-cod...-suffix-14.php
Old Jan 25, 2013 | 12:35 PM
restoman1's Avatar
restoman1
A 69 COPO 427 would be VERY questionable. There's almost no information on it and most people claim only one was ever built. Can you post a picture of the tank sticker?
Ed
Old Jan 25, 2013 | 03:01 PM
Hammerhead Fred
Here ya go!
6500 redline = L88 and 4.56 rear was only available with M22 & L88
Now you have number 2.....
Old Jan 25, 2013 | 03:10 PM
7T1vette's Avatar
7T1vette
There is no '69 engine that is spec'd for a 6300 redline. I do not know how the tachometers on the L-88's were marked; they were spec'd at 5200...but we all know that's a bunch of hooey.
Old Jan 25, 2013 | 03:20 PM
Hammerhead Fred
He says 6500 redline; 6300/6500 = L88
Waiting on the photos with ya.
Old Jan 25, 2013 | 03:50 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
I am betting it is a 1969 L88 M22 4.56 car in which case you got a gem if it is at all restorable. 100 point NCRS restoration is in order here. The tank sticker is gold. Parts are rare. Resto will be expensive but finished car is worth the effort and expense. There is a guy in New York with the machine that will deck it with correct broach marks and you can restamp the pad with a rentable correct gang stamp. This is part of this type of restoration but needs to be documented and disclosed. Trans codes and stamps are going to be someone elses area of expertise. Hope the differential is correct as they are scarce. There was one for sale in the C3 parts for sale section a while back as well as a carb. If you can document this as an actual COPO car I would bet your looking at a $500,000 car with a correct restoration. Good score!
Old Jan 25, 2013 | 03:54 PM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
To what do I have
Old Jan 25, 2013 | 04:11 PM
Hammerhead Fred
....you should also check for evidence of the transistorized ignition and likely F41 suspension.
Old Jan 25, 2013 | 05:27 PM
super-bee_ski's Avatar
super-bee_ski
Holy Crap!
HOLY GRAIL!!!!!!
OMG, go play the lottery cuz you are hitting a LUCKY STREAK!
Pictures would be NICE !!!
Congrads,
Nice find!
Old Jan 25, 2013 | 06:35 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
edit - Previous comments and advice withdrawn.
