C3 ride height
Old Feb 3, 2013 | 01:49 PM
yoesd's Avatar
yoesd
7th Gear
Default C3 ride height
Just completed a complete suspension rebuild (ball joints, A frame and sway bar bushings, new shocks, etc) on 69 coupe. Just mounted 255-60-15 tires to check ride height. Car appears to sit very high with approx 5+ inches between front wheel well openings and tires on front and about 4+ on rear. Anyone seen this before after suspension rebuild and any ideas on how this can be corrected? Thanks much for any ideas!
Old Feb 3, 2013 | 01:57 PM
C2C3PO's Avatar
C2C3PO
Have you driven the car much/at all since the rebuild?
Everyone says it takes a little time for all the components to seat/settle down.
I know this seems counter-intuitive but just from taking off and putting my leaf spring back in without adjustments the car sat high until I put some miles on it.
Old Feb 3, 2013 | 02:22 PM
yoesd's Avatar
yoesd
7th Gear
Thanks C2C3PO - does make me feel a bit better. Car has not been driven, or started yet following rebuild.
Old Feb 3, 2013 | 02:28 PM
C2C3PO's Avatar
C2C3PO
Oh, well for sure then things are going to change. Just rolling it back and forth on a driveway and jouncing things is going to "settle" a lot of that.
Just curious but did you put on Bilsteins?
Old Feb 3, 2013 | 02:52 PM
garygnu's Avatar
garygnu
are the front springs seated properly in their pockets ?
Old Feb 3, 2013 | 04:27 PM
Alan 71's Avatar
Alan 71
Hi y,
Also, did you wait to tighten the front a-arm bushing bolts and the 4 rear spring center mount bolts until AFTER you put the car back on the ground?
That procedure will help the car attain it's proper ride height too.
Regards,
Alan
Old Feb 4, 2013 | 07:33 PM
yoesd's Avatar
yoesd
7th Gear
C2C3PO - No Bilsteins - I installed new conventional shocks on both front and rear.
Old Feb 4, 2013 | 07:36 PM
yoesd's Avatar
yoesd
7th Gear
garygnu; Good thought - I remember rolling the springs into position, but worth checking
Old Feb 4, 2013 | 07:39 PM
yoesd's Avatar
yoesd
7th Gear
Originally Posted by Alan 71
Hi y,
Regards,
Alan
Alan; Great ideas - however everything was tightened with the car on jack stands. Maybe I should redo the procedure as suggested??
Old Feb 5, 2013 | 05:06 PM
Alan 71's Avatar
Alan 71
Hi y,
Both the AIM and the CSM have notes that the car's weight needs to be on the suspension BEFORE the front bushings and rear spring bolts are torqued to spec.
I think since your car is sitting SO high, you'll find there's a combination of causes.
Regards,
Alan
Old Feb 5, 2013 | 05:23 PM
redwhitekat's Avatar
redwhitekat
Mine had the same problem make sure you didn't install big block springs like my po did made the car sit very high
Old Feb 5, 2013 | 07:49 PM
yoesd's Avatar
yoesd
7th Gear
Hi y,
Regards,
Alan
Thanks Alan - I'm out of town now but when I return I'll go back under the beast again, loosen the suspension, put it on the ground and retorque. I'll let you know how this turns out. Appreciate your help!
Old Feb 6, 2013 | 11:33 PM
U17's Avatar
U17
http://tech.corvettecentral.com/2011...-height-guide/
Old Feb 7, 2013 | 05:53 PM
gcusmano74's Avatar
gcusmano74
Absolutely. The rubber bushings only have so much travel. If you tighten the suspension when the suspension is completly unloaded and hanging, when you set the car down on the ground, the bushings will be at their full upward travel, as designed. As soon as a wheel hits a bump, and the suspension compresses, the bushings will have to overtravel to allow the suspension to move. You will not get many miles before they tear, and you will be replacing bushings all over again.
Leave the bushing retaining bolts at least a full turn loose and put the car down on it's wheels. Next, settle the suspension, and then crawl under the car and torque the bolts with the car at normal ride height.
To C3 ride height
