1976 Dual Exhaust Conversion
Old Feb 6, 2013 | 01:48 PM
rklessdriver's Avatar
rklessdriver
Originally Posted by Brcmpbl
Will, thanks for the reply. Great information there.
Did you have to re-jet your carb when you switched the system from the stock 2-1-2?
I didn't notice any difference in how it ran after the exhaust install with the stock Q-Jet - BUT some clown had dicked with the mixture screws on the factory Q-Jet before I bought the car and he managed to crack the base plate getting the plugs out of it... so it always had a small vaccum leak.
I eventually replaced that factory 79 Q-Jet with a used pre smog Q-Jet that a CF member gave me. All I did was set the idle mixture correctly and then set the timing up a few degrees... The car runs great.
I don't think you'll have any problems with the tune because of the exhaust change.
Will
Old Mar 26, 2013 | 08:53 PM
Brcmpbl's Avatar
Brcmpbl
Quick follow up to this thread for anyone interested in a similar change of systems. Turns out that 1975-1976 cars with AIR do in fact have a bracket and hole for a pipe that connects the AIR pump to the front Y-pipe, rather than the exhaust manifold as in other years and applications. The picture in this link shows it: http://www.parts123.com/parts123/yb....Z5Z5Z50000050G
The dual exhaust kits sold by Corvette Central do not have this hole and bracket. Is there any way around this without dumping the AIR system (not going to do that)? If not, I will likely just stick with the stock 2-1-2 and replace my tired mufflers, and maybe have the exhaust shop swap in a test pipe in place of my cat.
Thanks.
Old Mar 27, 2013 | 11:37 AM
rklessdriver
Thanks.
Would be easy for a muffler shop to weld a stub tube in the new pipe so you can hook up the AIR.
Will
Old Mar 27, 2013 | 11:58 AM
Brcmpbl's Avatar
Brcmpbl
Hi Will...anticipate any issues of any kind with having the AIR system pumping into the passenger side exhaust and not the driver side?
Old Mar 27, 2013 | 06:41 PM
rklessdriver
No problems.
Will
Old Mar 28, 2013 | 12:37 AM
Brcmpbl's Avatar
Brcmpbl
Thanks for the input Will.
