I know there is several post concerning temp gauges but here's another one. While having some ignition issues I removed my sending unit wire to change plugs and guess what? I forgot to plug it back in before I took a test run. while driving I notices my gauge jumping around and immediately realized what I had done. After returning home I noticed the temp wire had been grounding out on the headers so I thought no big deal i'll just plug it back in. Now it doesn't work, even when you ground out the wire the temp gauge will not respond. So my question is could the jumping around have caused my resistor to short out or kill my gauge? The gauge wire insulator was melted some but not much. this is on a 1970
May have to rewire if it is burnt. Probably laid on the header for awhile and burnt the wiring. Without a pic, I would think the connector should still be fine.
Yeah maybe, but it was only on there a very short time off and on. Only went couple of miles before I realized the problem, and only the connector tip was melted. I really don't think it got hot enough to hurt the wire, but I am gonna check that out when I get back to the car. Thanks..............
Well this is interesting because if the wire was melted to the header it would be grounded out and go to full hot and this would just be the temp gauge. So I'm wondering two things. 1) did the heat go up the wire and cook the gauge?.. or 2) is there a short somewhere else and you have two problems.
If the resistor is blown, the needle on the gauge will point to just below the right hand face rivet..
What is the gauge reading when the key in on? This video may also help you diagnosis your problem.
There would not be a 'heat transfer' problem with manifold heat feeding through the sender wire. If that were the case, ALL of the insulation on that wire would have burnt off, and I feel certain that it did not.
I think the heat that it did see, probably damaged the connection between the end connector and the wire, so that the sender no longer transferred its signal into the wire.
It is possible that the rapid, erratic connection did some damage to the gauge internals. Not that likely....but it could happen.
I'm with you on the heat.. it would have smoked all the insulation off.
I wonder it if hit something with power on it?
Knowing what the needle is pointing toward will go a long way in figuring out the issue.
The erratic connection should not hurt it, at least in all the testing I've done it never causes a gauge failure.
thanks for all your response guys. I work weekends and haven't had time to address this issue again but i'm going dig deeper Monday and make sure the wire hasn't broken somewhere between the connector and gauge. Thanks again
Update here on the temp gauge. It was a break in the sending unit wire just past the connector. replaced the connector and all is good........BOY I FEEL DUMB!!!!........ thanks
