Firewall installation replacement ?
Old Feb 24, 2013 | 10:37 AM
Tampa 68's Avatar
Tampa 68
Default Firewall installation replacement ?
68 my fiberglass firewall barrier is shot my feet are getting hot any options on this? Can I just pull it out and replace it are better options available?
Old Feb 24, 2013 | 10:43 AM
hugie82's Avatar
hugie82
Is it the toe kick or the vertical fire wall that's getting hot? If its the toe kick I would wrap the exhaust with DEI heat wrap. It's cheap and easy but it will rust your headers faster if you drive in bad weather....
Old Feb 24, 2013 | 10:50 AM
Tampa 68's Avatar
Tampa 68
I have side pipes it's the floor pan area that is torn away. Not sure how much heat the factory shield provides I was thinking about some type of dyna-mat style option.
To Firewall installation replacement ?
