looking for real technical info
Gears were similarly processed to provide the core strength for the teeth to absorb the loading stresses of constant use, and then surfaced hardened on the wear surfaces for good abrasion/cracking resistance. For this process, most of the gear surfaces were copper plated prior to carburizing [except for tooth and wear surfaces] so that only those needed wear surfaces would be surface hardened. The roots of the teeth were Cu masked so that they did not become over-hardened and too brittle, thus cause cracking [and later propagation] from bending moments during operation. After hardening the wear surfaces, the Cu masking was then stripped from the part. Tooth surfaces may also have been nitrided for additional wear resistance.
In that differential unit, there were likely dozens of different heat treat process formats used [differing furnace atmospheres, temperature levels, time, quench types, etc.] on those parts used to produce a product that is no larger than it is, could tolerate the loading and wear of use [and sometimes 'abuse', like we prefer to do
] for many years with only occassional lubrication changes. If the general population knew what it actually took to produce that differential, they would surely be totally dumbfounded.Good luck with your project.
