HEI system and dwell angle?
Old Mar 30, 2013 | 08:21 PM
7vette6's Avatar
7vette6
Default HEI system and dwell angle?
I finally got around to setting my timing and changing the springs in the distributor. I know step one is checking the dwell angle. But since I have HEI system do I need to check my dwell angle or is it preset and unchangeable?
Old Mar 30, 2013 | 08:24 PM
jnb5101's Avatar
jnb5101
i've installed two hei's. never gave the dwell a thought! you do have to adjust the vacuum can, though.
Old Mar 30, 2013 | 08:27 PM
7vette6's Avatar
7vette6
Oh really? could you please give me some info on this?? what did you do to your vacuum cannister and why?
I just thought my current vacuum advance would work fine with increasing the timing and switching to manifold vacuum
Old Mar 30, 2013 | 08:51 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
The dwell angle automatically changes with RPM and battery voltage. It does this to keep the coil charged up at high RPMs, and preventing burning up the coil at low RPMs. It also compensates for the battery/alternator voltage being too high or too low.
The module does all the work. Nothing you need to do.
Old Mar 30, 2013 | 09:06 PM
jnb5101's Avatar
jnb5101
go to msdignition.com. they have installation info on their street fire hei distributor that has a chart showing the engine vacuum, degrees of advance and the number of turns the advance screw needs to establish that number of degrees. there may be other sites that have the same info. just google it.
Old Mar 30, 2013 | 10:20 PM
7T1vette's Avatar
7T1vette
That is for an MSD electronic ignition system...not a GM H.E.I. system. The only 'adjustment' on the HEI system is to reposition the distributor.
Old Mar 30, 2013 | 10:24 PM
7vette6's Avatar
7vette6
yes. Now im pretty sure I have the ar-10 vac can. which has a 3-5 start "hg and 9* distributor advance. My main question is if this can is o.k. to use, or if I need to buy a new one.
Old Mar 30, 2013 | 10:51 PM
7T1vette's Avatar
7T1vette
The type of vacuum advace can you have is (or should be) dependent on the amount of vacuum your engine produces at idle. Lars has a good write-up on this issue. You should send him an e-mail and request a copy of that paper.
V8FastCars@msn.com
To HEI system and dwell angle?
