Calling all inventors
Old Apr 9, 2013 | 01:49 PM
7dSHARK's Avatar
7dSHARK
Default Calling all inventors
I have a 70 convertible with stationary seats bolted directly to the floor and very close to a non tilt/tele steering column. I have the same problem getting to my fuses that everyone else does but made worse by my seat configuration. I can barely see them and have to have a slender friend remove and replace them. I am going to make something that allows me to remove/replace fuses at a comfortable distance. Don't want to invest a lot of time and effort fabricating something only to find out one or more of you guys have an easier more obvious tool or solution. Thanks for any input. As always pictures are appreciated. Most Know, but the 70 has the round style glass fuses..........
Old Apr 9, 2013 | 06:58 PM
doctorgene's Avatar
doctorgene
Yes Sir; They make a fuse puller to pull the round glass fuses. I have one for the next generation of fuse panel also. I think I've seen these on the help boards, or I'm sure Lectric Limited might have them. 1-708-563-0400 Have a great one. Gene
Old Apr 10, 2013 | 12:26 AM
ramair_bryan's Avatar
ramair_bryan
Sorry doc..........thats designed to make slender friends..............
Old Apr 10, 2013 | 10:53 AM
doctorgene's Avatar
doctorgene
Well I guess you are right, I put on a couple of extra pounds each year. I pulled my seats to get into the fuses last year. LOL Have a great one. Gene
Old Apr 11, 2013 | 09:30 PM
7dSHARK's Avatar
7dSHARK
Was hoping for more options. If//when I make my prototype it's going to have a led light included. Last chance for someone to stop me with an easier, more obvious solution.
Old Apr 12, 2013 | 08:17 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by 7dSHARK
...I have a 70...with stationary seats...
Both seats should move forward and backward. They are stationary only if your seat tracks need to be cleaned up.
...I am going to make something that allows me to remove/replace fuses at a comfortable distance...
Robot?
Old Apr 14, 2013 | 02:30 PM
KenSny's Avatar
KenSny
I used a 10 year old child who could scrunch up and get in there. Pulled and replaced a fuse for me in about 5 minutes. Showed him a pic of the fuse box and which one to pull, how to use the puller and to work he went.
Old Apr 15, 2013 | 07:42 PM
7dSHARK's Avatar
7dSHARK
Robot?
A robot would be cool, but I'm guessing someone has an easier solution. Probably some every day item from the kitchen or garage. My seats are aftermarket and are bolted directly to the floor. I can get in there, but there is always a concern that I cant move once inside or can't get out.
To Calling all inventors
