Rear Strut Rod Question
Old Apr 21, 2013 | 06:41 PM
WhyFly's Avatar
WhyFly
Default Rear Strut Rod Question
I didn't want to do it but I had No Choice..after a couple weeks of spraying several different penetrating oils & heating the heck out of them, and swearing like a trooper I finally admitted defeat and cut out the rear strut rods on my 79 coupe. I am now going to order some new ones and wanted to ask some of the very knowledgeable members here about the replacements.. I'm thinking of ordering the n heavy duty type that say they are less likely to deviate from the set camber than the stock rods and have the sleeve type adjustment as opposed to the traditional offset camber bolts and washers. I'm just wondering how many of you folks have used these and what you think of them before I go ahead and order them? Have you had good results from them or would you stay with the stock rods? Any feed back would be greatly appreciated..Thanks Folks.. Safe Driving
Old Apr 21, 2013 | 07:33 PM
my 76 ray's Avatar
my 76 ray
I have the type with Heim joints on the end. They work well.
Old Apr 21, 2013 | 07:49 PM
Mike Ward's Avatar
Mike Ward
The so called 'smart struts' are often seen to work themselves loose. Far more often that the stock struts- as you've seen with your recent experience.
If you insist on getting them go for rubber or Heims joint ends, not poly.
Old Apr 21, 2013 | 07:59 PM
drwet's Avatar
drwet
I have the poly adjustable strut rods ffrom Vette Brakes on my '79. They have been there for almost 20 years. I would never consider using the stock design unless originality was a factor. The adjustable strut rods are vastly superior to the General's original design. If you have to replace them anyway, its a no-brainer.
Old Apr 21, 2013 | 08:04 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Definitey get the adjustable type. I've used poly and heim style with equal success. Never had one come loose yet. They were all from Vette Brakes.
And while you're at it I'd use the Smart Strut bracket to give you some more adjustability if you think you'll ever need it.
JIM
Old Apr 21, 2013 | 08:06 PM
zwede's Avatar
zwede
Get the ones with the heim-joints. I've been running them for a few years and they work great.
Old Apr 22, 2013 | 02:36 AM
dembo's Avatar
dembo
No one has issues with heim joints squeaking then? I've driven 700 miles with them, they are great but after every trip they squeak like crazy. Dry teflon lubrication works but don't feel like doing that after every drive and makes me want to go back to stock (not the poly adjustable as they are more prone to turning loose)... (I got this kit btw ecklers heavy duty strut rods)
Old Apr 22, 2013 | 06:14 AM
jb78L-82's Avatar
jb78L-82
Heim joint struts-eliminates the bushing both rubber and poly. No squeaks for years.Much stronger! Get the competition adjustable struts. Got mine from midamerica a few years ago for $100 on sale. No brainer.
Old Apr 22, 2013 | 07:16 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
There's a company called "Seals-It", that sells rubber boots for Heim joints. You might want to look them up. You could grease up your Heims, then these boots will keep the dirt out.
Old Apr 22, 2013 | 09:14 AM
427Hotrod's Avatar
427Hotrod
Mine are greasable. Theoretically not as strong....but no issues for years. Just grease them every year or so when I think of it.
Never had a poly one come loose either. If you did...something was wrong.
JIM
Old Apr 22, 2013 | 12:20 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Stay with stock and use stock bushings. Did your rear camber ever change often enough to justify smart struts?
Old Apr 22, 2013 | 01:32 PM
Marlin's Avatar
Marlin
Good thing we all agree, I'm sure the OP is greatful.
for me I'm going to install the adjustable ones with poly. But I like my car to be firm and handle as well as it can. If you are just a crusier type then go with the oem style.
Old Apr 22, 2013 | 03:08 PM
terrys6t8roadster's Avatar
terrys6t8roadster
check out 'dragvette' 6-link setup. his strut rods use heim joints and anodized rods.
Old May 8, 2013 | 01:56 AM
WhyFly's Avatar
WhyFly
Default Can't Thank You Folks Enough
After reading all of your replies, I think I'm leaning to the Helm-joint. As you all know, there are several suppliers and prices seem to be pretty close. I need them shipped to the Great White North so I guess the difference will be who scewers me the least for shipping and the brokerage fees.. and how fast they ship them. At least our Canuck Buck is pretty close to par with the Eagle. My car is up on my hoist just screaming fix me and if I order soon, I might get the parts in three weeks...:-) summer here is usually only about eight...weeks...Ok give or take.. Thanks People.. Best car forum and people on the web...
Old May 8, 2013 | 07:39 AM
jb78L-82's Avatar
jb78L-82
I don't have the Seals-it rubber boots for Heim joints but would consider getting them if I was putting on the competition adjustable struts today if I was doing the job again-would probably put these boots on if I have to take my struts off now for some reason but not going to put the boots on if I don't have a reason to take the struts off since I have had no issues-just a precaution!
Old May 8, 2013 | 10:34 AM
qwank's Avatar
qwank
I put the corvette central competition heim joint style on my car a few weeks ago and yesterday I noticed there is play in them if I grab the wheel at 12 and 6 with the car jacked up. Its not the wheel bearing moving as I can actually see the heim joints move.
Old May 8, 2013 | 11:10 AM
ToniH's Avatar
ToniH
I installed the VBP HD strut rods to mine. Very happy with them.
But like it was mentioned before: they can loosen up. We've had couple of cases locally, mine included. Friend of mine had one come loose when driving but luckilly no damage, just a weird moment while turning at slow speed. After that I inspected mine and one of the lock nuts was spinning freely. Since I have inspected them couple of times per summer. It seems to me that they are like alu wheels: after initial tightening you need to recheck them after some driving and retighten if necessary - then they seem to stay tight. Mine has been installed for 3 years now. This is a 100 year old tech which is widely used in aircraft, sports- and racecars, so the tech is sound but they require some attention from the owner.
So, inpect them every now and then to be safe. Or use blue Locktite - or lock wires.
PS. I don't like the poly versions. Think about it: the end piece is basically a bolt welded to a piece of tube. I've seen a pic of this weld breaking off.
To Rear Strut Rod Question
Old May 8, 2013 | 11:28 AM
Mike Ward's Avatar
Mike Ward
Originally Posted by ToniH
This is a 100 year old tech which is widely used in aircraft, sports- and racecars, so the tech is sound but they require some attention from the owner.]
Actually no- turnbuckles are NOT designed to be subjected to any torsional force at all. That's what causes the them to loosen despite the lock nuts. Poly bushings just makes it worse.
Old May 8, 2013 | 11:57 AM
ToniH's Avatar
ToniH
To me it seems that poly ends direct much more torsional forces to the strut rod ends than heim jointed ends.
End result can be something like this (questionable weld, rust, torsional forces and a snap!):
Picture by a forum member (cannot remember who).
Old May 8, 2013 | 12:27 PM
noonie's Avatar
noonie
Heims are designed to effectively eliminate torsional load and keep all normal operation at either tension or compression load (axial loads).
That's why the principle is used as ball joints, tie rod ends, rack and pinion steering etc.
They will NOT cause adjustable struts to loosen.
That's nonsense.
My struts have been on for years, set at camber adjustment once and never touched since and the car gets driven year round.
Here is a primer on joints.
http://www.therangerstation.com/Maga...008/joints.htm
