Headlight Warning Switch
Old Apr 22, 2013 | 07:36 PM
jimvette999's Avatar
jimvette999
Default Headlight Warning Switch
Anybody here come up with a better switch than these fragile $30 switches? I ran a search but saw no alternatives for the original style switch. Just info about disconnecting, replacing with the same, or adjusting the switch. I'd appreciate any help.
Thanks,
Jim
[IMG][/IMG]
Old Apr 22, 2013 | 09:01 PM
vetteguy22's Avatar
vetteguy22
Thanks,
Jim
[IMG][/IMG]
Just found that I have a broken switch also. When I was disconnecting the wiring, one of the wires broke at the pig tail, so now I have to find one of those too. Anybody have any suggestions?
Old Apr 22, 2013 | 09:52 PM
drwet's Avatar
drwet
What is a headlight warning switch?
Old Apr 22, 2013 | 10:05 PM
LT-1 kid's Avatar
LT-1 kid
I have a bunch of old wiring harness that I could cut off that pigtail and send to you.
Old Apr 23, 2013 | 09:34 AM
Alan 71's Avatar
Alan 71
Hi drw,
The headlight warning light in the center dash cluster should stay illuminated until the the headlight door is fully open when you have the headlights turned on. The button on the switch sends the signal that turns off the light.
Regards,
Alan
Old Apr 23, 2013 | 09:47 AM
Commodore's Avatar
Commodore
I could swallow the $30.00 hit for the [fragile] switch more comfortably if the switch had a metal rather than plastic case and bolt sticking out of it. My '75 currently has a broken headlight switch .
If you don't use your theft alarm I believe the alarm key activates the same switch if you'd like to hang on to your $30.00 a little longer. There aren't any choices for replacing this fragile switch that I've been able to find so far. Do not over tighten the nut when installing these switches as doing so will shorten the time you will get before another $30.00 departs your wallet .
I'm tempted to slather my switches (the good one as well as the broken one) with epoxy to make the switchs break proof. Be careful around the button face. If you go the 'Bubba' epoxy route and the switch dies all you'll need to do is snap the puppy off with some pliers - there isn't anything inside it worth preserving anyway. Don't forget to keep $30.00 handy
RB
Old Apr 23, 2013 | 10:14 AM
Mike Ward's Avatar
Mike Ward
Unless someone is a complete klutz, the switches should last the life of the car. One of mine is the 40 year old original. I klutzed the other one 20 years ago thinking I knew what I was doing.
Old Apr 23, 2013 | 10:37 AM
Alan 71's Avatar
Alan 71
Hi,
Many switches have been damaged/broken by having someone open or close the headlight door by hand. It's the perfect handle to grab when you reach up under there; and the switch's body snaps at the threaded end.
Some people have found the switches sturdy enough to rebuild.
Regards,
Alan
Old Apr 23, 2013 | 11:20 AM
drwet's Avatar
drwet
Originally Posted by Alan 71
Hi drw,
Regards,
Alan
This just in from the 'You learn something new every day' department: I have owned my '79 for 20 years and I didn't know there was such a system on board. Apparently there is still one part on the car I haven't changed. I'll break out the wiring diagram tonight and see what I have been missing.
Old Apr 23, 2013 | 12:12 PM
Brcmpbl's Avatar
Brcmpbl
Changed both of mine in my 1976, but that was in fact due to my being a knucklehead and overtightening them...the ones in my 1970 are ancient, maybe original. Just get the correct switch and throw it in there and don't overtighten it and it will last a very long time.
Old Apr 23, 2013 | 12:29 PM
drwet's Avatar
drwet
There's two of them?? Where are they located?
Old Apr 23, 2013 | 12:32 PM
Brcmpbl's Avatar
Brcmpbl
One for each headlight. If you get under the nose of your car and look up in the closed headlight you'll see them in about the centre.
Pic in this thread...Alan's car and pic:
http://forums.corvetteforum.com/c3-t...oes-it-do.html
Old Apr 23, 2013 | 01:08 PM
drwet's Avatar
drwet
The picture's not real clear. Are we talking about the black object centered between the two springs with the green wire running behind it?
Old Apr 23, 2013 | 01:11 PM
Brcmpbl's Avatar
Brcmpbl
It is right below the springs with a white wire going into it from the right side of the picture. Can see a little button it and a nut on the left where it goes through the bracket. It is black, like the picture at the top of the thread.
Old Apr 23, 2013 | 01:13 PM
Mashman's Avatar
Mashman
Old Apr 23, 2013 | 01:26 PM
drwet's Avatar
drwet
Much better picture. Thanks!
Old Apr 23, 2013 | 07:12 PM
Commodore's Avatar
Commodore
Depending on how often one's 30 plus year old car was and is driven during a year, icy cold winters [that some of these cars experience] followed by blistering hot roads in the summer likely raises enough hell with plastic (ie. the little switches in question) to make them fragile. Given those extremes it's possible that just every day road and car vibrations have brought many of these switches to an early end. That said, I still view these switches as poorly designed. The load on the switch should have been compressive like the courtesy light switches light on our doors frames.
RB
To Headlight Warning Switch
Old Apr 24, 2013 | 02:07 PM
jimvette999
The post on the switch is actually fused to only half the switch body and due to this poor design along with being made of plastic, these don't take much to break. Maybe I have over-tightned it but I really don't think so... just old and brittle like me.
Thanks for the replies guys... I've done a little sumpin' I'll post a picture of soon for your amusement.
Jim
Here's a crappy picture... I cut 90% off the head of a stainless bolt and epoxied it to the switch. I sanded the switch and bolt head with course grit to give it something to bite/hold onto. Wish me luck!
[IMG][/IMG]
Old Apr 24, 2013 | 02:36 PM
Mike Ward's Avatar
Mike Ward
Wow- moaning that a 40 year old switch broke.
Do you think that a metal-bodied switch would been a better idea with it's obvious exposure to moisture and road debris?
Old Apr 24, 2013 | 03:16 PM
jimvette999
These aren't the originals.... they're about 10 years old and on a garage kept ride. And yes, a metal bodied switch would have been much prefered. These have the stud bonded to half the body as previously mentioned and shown in Alan's picture posting. Maybe a plastic body with the stud bonded to the entire body would have lasted much better. Thanks for your reply/comments.
Jim
