I did a bad thing...
I think the engine now has to come out (crank repair/replace).
Don't ask me how disgusted I am with myself right now.
DUB beat me.
May have to use the easy out or welder option. Perhaps I can hire the repair via Angie's list if it comes to that.
Thanks!
I removed mine with an eazy out. The bolt never breaks off square so you will not be able to drill a hole on the stud. I used a 7/16 socket head cap screw. The threaded end fit into the hole in the crank. Cut the thread end so it just touches the broken stub in the crank and the shoulder of the head bottoms on the end of the crank. Drill a 1/8" hole through the center of the bolt. You now have a drill guide to drill a hole in the center of the stub. Go to an industrial supply house or Graingers and get a 1/8" Left Hand drill bit.
If you are lucky the left hand bit will back out the stub. Make sure you run your drill in reverse! If not keep drilling at least 1/2" into the stub. Use the eazy out and back it out.
BTW, I bought the install tool from Summit. I called them and they credited the cost toward a better one made in the US and discounted it and shipped for free with a return shipping label for the busted one. Great customer service!
Looks like I have a good job for my drill press. I have a bunch of cap screws and will see if one is the right size, cut it to length and drill the 1/8" guide hole in it.
Good info. Thanks for sharing.
I used my digital camera on Macro to take a photo of the end of the crank to see the broken stud inside. You can't get your head down there to see it. I also used a right angle drill so I didn't need to pull the radiator.
Good luck.
I've done the "weld a nut on" thing before, with great success (on an approx. 1 & 1/2"-long steel bolt, into an aluminum bell housing, i.e., 14 years of galvanic corrosion [between dissimilar metals] plus road salt) but never in a crank.
texasbaehr's "drill guide" idea is brand new to me--and a GREAT IDEA, IMHO. Thanks!
To the OP:
If anyone welds on your car, make sure the battery is disconnected first. And if they don't already know to do that, I wouldn't let them weld on my car--just my .02.
Oh--I thought enthusiasm for Easy-Outs had cooled, due to the fact that if THEY break off, they're harder to drill through than the original bolt. But I can see why they're being recommended here, because the bolt in question is not frozen into place by years of rust--it should back right out. Having said that, I would buy the highest quality Easy-Out I could, to avoid any problems.
Good luck!
And please take some before and after pics, so we can help you celebrate.
Peter
Good luck.
Tried a telescopic magnet just in case; no 'pull'. The damper will need to come back off (hope for last time). Will fabricate/drill the guide on my drill press today.
Good luck.
So what is a good USA made brand of tool to buy?? Is Moroso good?? Any others??
