Hood Won't Catch
Im having trouble with my hood not catching on the right side after remounting. I have centered the pins (see photos), there is no tension in the cable, but the hood will still not catch.
Left catch.
Right catch.
Does anyone have some insight for rectifying this problem?
Thanks for any help.
Mark
By the way it's just the right one that won't catch.
Thanks,
Mark
Maybe try loosening the nuts that hold the hood pin/tension spring and move the assembly toward the curved leading edge of the latch. You want the pin centered on the line that represents the radius of the curve on the latch edge when the latch is engaged. This location isn't necessarily the center of the hole in the latch plate and hood.
If you took your hood off and nothing else changed, it seems that it is not back in the same place as it was. Is the gap on either side of the hood to the fender the same (hood centered)? You could loosen up the 6 hood hinge bolts and move the hood around while it's closed. If you get it to latch in some position, see where the hood needs to go from there to get it centered between the fenders. If re-locating the hood, moves the latch closer or further away from the pin, you have to move the pin assembly accordingly.
This adjustment is incredibly sensitive. I've had my present Vette for 20 years, every time I hit a RR track, bump or quick undulation in the road, the right side of the stock hood would release, inspite of numerous trys at adjusting it. At some point, I finally got it right and you could run over a cow and the latch stayed engaged. Same with the L88 hood I have now.
Good luck.
Good luck.
To clarify the tension on the cable, I was talking about the cable between the latches and the only tension on the cable is what is created by gravity.
I look forward to seeing your photo.
Thanks, Mark
