corvette brakes
Old May 3, 2013 | 09:21 AM
  #61
Tom454's Avatar
Tom454
Originally Posted by jb78L-82
If your having that much trouble bleeding the brakes, something else is wrong in the system. I have bled the brakes on my C3 probably 6-7 times in 30 years, changing the fluid every 3-4 years and replacing the OEM cailpers in 1985 with SS ones with regular lip sealed ones, and I have never had an issue-simple 2 person job, no different than the many other standard type brakes that i have bleed on other cars in the same time period!
Again, if bleeding the brakes is requiring a lot of effort on a C3, than the system is compromised some where in the system or the operator is doing something wrong!
Old May 3, 2013 | 04:05 PM
  #62
Belgian1979vette's Avatar
Belgian1979vette
Originally Posted by GDaina
Bleed the brakes....get all the air out of the system...use a small jar fill it partially w/brake fluid, attach a vacuum hose to the bleeder, the other end in the jar..bleed...when there are no more bubbles...next bleeder.
That's the way I did it 2 times. No more air bubbles came out. Pedal is firm.
Could the prop. valve be the issue ?
