1980 alignment
Old May 1, 2013 | 02:19 PM
80L82's Avatar
80L82
Default 1980 alignment
I have a 1980 that I just had aligned because we put new strut rods on it. Tires are pretty new. The alignment guy comes highly recommended and has worked on vettes, drag cars, etc. I got it back and it was veering left on the highway (flat sections). I took it back and he double checked it and when I got it back it's still doing it. Is there something else I should be looking at?
Old May 1, 2013 | 02:38 PM
wombvette's Avatar
wombvette
Steering valve adjustment.
Old May 1, 2013 | 02:48 PM
80L82's Avatar
80L82
It veers when I let go of the steering wheel. Would that still be related to the steering valve?
Old May 1, 2013 | 02:50 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Ditto...
Old May 1, 2013 | 03:20 PM
jim-81's Avatar
jim-81
I think to check the steering valve, you would prop up the front wheels, start the car and center the steering wheel. If it drifts or pulls to one side then it would be the steering valve. I have never done this but I think this is what I heard...
Then to adjust the steering valve, there are some info sheets on Willcox's site.
Jim
Old May 1, 2013 | 04:52 PM
80L82's Avatar
80L82
The work was done last fall and I'm 99% sure he said he did that. (the steering valve)
Could tires do it?
Old May 1, 2013 | 05:03 PM
Jud Chapin's Avatar
Jud Chapin
Could tires do it?
Yes they could. To check, rotate front to back.
Old May 1, 2013 | 05:10 PM
80L82's Avatar
80L82
I'll give it a try, thanks!
Old May 1, 2013 | 05:44 PM
Jud Chapin's Avatar
Jud Chapin
You're welcome.
Old May 1, 2013 | 06:12 PM
John A F's Avatar
John A F
Check for a sticking brake caliper.
Old May 1, 2013 | 07:34 PM
Jud Chapin's Avatar
Jud Chapin
It would probably be easier to just swap the 2 front tires.
To 1980 alignment
