Water pump
Old May 12, 2013 | 09:03 AM
70demi's Avatar
70demi
Default Water pump
Just had a alumnin water pump (on my 350)installed at the Garage,. They installed a 1/2" STEEL pipe plug with silicone on the top of the pump,as I recall ,steel & allumnin don't match?(Doesn't it cause some kind of a chemical reaction? Thanks
Old May 12, 2013 | 09:06 AM
7t9l82's Avatar
7t9l82
yes before long it will seize in place the steel will corrode and leak eventually. either find an aluminum plug or even brass. galvanic corrosion .
Old May 12, 2013 | 11:18 AM
BB68Vett's Avatar
BB68Vett
I think you'll be OK with stainless steel into aluminum. Stainless Works has these water pump fittings in stainless.
Old May 12, 2013 | 11:32 AM
7t9l82's Avatar
7t9l82
Old May 12, 2013 | 12:46 PM
70demi's Avatar
70demi
Default water pump
Originally Posted by 7t9l82
I kind of thought I read or heard of that combination was a no go. Thanks guys,ordering the stainless
To Water pump
