'71 Won't Idle
Old May 12, 2013 | 02:38 PM
jbass's Avatar
jbass
4th Gear
Default '71 Won't Idle
I've been browsing around, but can't seem to find this exact question. Yesterday I was cruising around town when all of a sudden at a red light I noticed my RPMs had fallen to around 400. I was on my way home, so just figured I'd check it out then, but after a few lights it began to sputter and it died. It conescutively died at 3 lights before I got home, and I immediately tried to see what was wrong. I have cleaned the carb and checked the fuel mixture. Fast idle is fine, but slow idle it not. If I adjust the idle to 600 RPMs or below, the car will die. If I adjust the idle above 600, the engine will rev itself and keep jumping until it reaches about 1100-1200 RPMs. Next I was going to check the vacuum lines, any other suggestions? Thanks.
Old May 12, 2013 | 03:44 PM
my 76 ray's Avatar
my 76 ray
Checking for a vacuum leak is a good place to start.
