1972 Passenger Headlights Problem
Old May 25, 2013 | 02:01 PM
Miccar's Avatar
Miccar
Default 1972 Passenger Headlights Problem
The driver side headlights work fine, but my passenger side high and low beams sometimes go on and off. It sound like it might be a ground issue. Does anyone have any idea where I should look? Thank you.
Old May 25, 2013 | 05:54 PM
Alan 71's Avatar
Alan 71
Hi M,
Same question as your 4:12 thread. Same reply.
Regards,
Alan
Old May 25, 2013 | 10:44 PM
Miccar's Avatar
Miccar
Default 1972 Headlights
Hello Allan,
That was the tail lights. Now it's the headlights. I suspect a ground is loose.
Old May 25, 2013 | 11:10 PM
johnnyjaws's Avatar
johnnyjaws
unplug the lights and run some emery paper over the light posts may help
Old May 26, 2013 | 01:48 PM
Miccar's Avatar
Miccar
Light plugs were loose. Snugged them up and works fine. Thank you.
To 1972 Passenger Headlights Problem
