Crate engine specs
Here is a MODIFIED ZZ4 w/ LT4 (GM's "hot cam") and home ported heads with Manley raceflow valves. There are more powerful engines, but this one has served me well for the last 15 years. These numbers are off a chassis dyno. I'm estimating that I'm close to 400HP now. Wish I had dyno results from when it was a plain ZZ4 but I'm guessing the 350HP claim is pretty accurate.
On a side note, looks like I'll be seeing very similar numbers with my $1200 Craigslist piece mail build.
So your off a little in your assumption and being a huge fan of craigs list I wish you luck with your build , and hope it is as good as a zz4 ...
..... I mistakenly thought the OP was talking about a 74, A 75 l82 is more compatible to the 74 base l48.... and if you were to rate a 74 l82 the same way as the zz4 is rated it comes out to about 333hp...... 250hp is supposed to be at the rear wheels in 74 as I understand it and after you add the 25% or so drive train loss you would have about 333hp..... Which means a zz4 would have about 260-270 HP at the rear wheels and 355hp at the crank.... which isn't much of an upgrade until you get into the 75 and up years when emissions made the HP pathetic compared to its predecessors.
Maybe I'm understanding things wrong if so someone please enlighten me?
thanks in advance for any input..
Think of it this way. You can rotate a transmission by hand since your producing very little torque at a very slow speed (i.e. almost no HP). If the transmission took say a constant 20 HP to rotate, an avg. human wouldn't be able to rotate the gears. When in fact, its quite easy to rotate a transmission.
Oh by the way a side note on the dyno plot I presented above. The transmission losses could have been a bit higher than normal because I wasn't in high gear with the transmission in a 1:1 gear ratio as is typically used for dyno runs. I was only in 4th gear which has a 1.24 ratio. This means that the input and output shafts were not locked together and the power was going thru an additional set of gears.
I did alot of research before I purchased and for a reasonable amount of money they built me a pretty good motor.
406 with 530hp (on the engine dyno) on pump gas. 10:5:1 cr.
I then put the engine without changing anything and put it on an chassis dyno and got the 23% loss. A TH400 can eat up to 35% or more with the big blocks in the early 70's.
For those who weren't privileged to all the debates, a big drum type chassis dyno measures the rate of change of speed of the drums and like I said while not completely linear a C3 with a 600hp motor in my car loses 23% and if I drop in a 1000hp engine I would expect about the same percentage loss within a few percentage points on the down side
I don't believe it's a percentage loss or a fixed loss but there are for sure fixed losses in a drivetrain which would make the losses mixed, some fixed and some varying. There are a number of things that have a fairly constant loss vs rpm number, such as the bearing friction and gear box windage. Also, the loss due to the sliding friction as the gear teeth work will be fairly constant over a certain power range. After all, the teeth face are not sliding steel on steel, they're sliding with an oil film between them. The film will keep the sliding effort fairly constant until it starts to be really stressed, in other words as you reach and go past the design limits of the gears.
I recall a thread where Tony Mamo had commented on this with some data but this is all I could find.
http://forums.corvetteforum.com/1575738864-post38.html
The thing with the above data - you could argue it could go either way by arguing errors introduced by the dynos on the different days. Still, the data is closer to a fixed HP loss than a percentage HP loss.
Also, you have to remember that engine hp is typically measured on a brake dyno and rwhp is typically measured on an inertia dyno. They measure in a different way which can skew the engine vs wheel HP results.
