Crate engine specs
Old May 25, 2013 | 07:07 PM
brad1964's Avatar
brad1964
Default Crate engine specs
Which is the best? 1 piece rear main seal or 2 piece?
Old May 25, 2013 | 07:33 PM
augiedoggy's Avatar
augiedoggy
The newer on piece is superior since the newer blocks are set up for a roller cam also...
Old May 25, 2013 | 07:49 PM
loup68's Avatar
loup68
Army
Buy a ZZ4, you will be very happy. 350 cu. in. 355 HP and 405 ft. lbs of torque. This is the same torque as a new 2002 corvette. Lou.
Old May 25, 2013 | 07:59 PM
augiedoggy's Avatar
augiedoggy
Only the new corvette has that amount at the rear wheels.... in a c3 it will be 15-25 percent less at the rear wheels than the engine is rated at.
Old May 25, 2013 | 08:33 PM
AGVI's Avatar
AGVI
Canadian Events Coordinator
Buy this...be happy.
http://www.ultrastreet.net/engines/5...wg_lowdeck.php
Old May 25, 2013 | 09:39 PM
TimAT's Avatar
TimAT
Or if that's not quite enough, there's the 925HP, 598CI low deck "Twisted" for just a little more $
Old May 25, 2013 | 10:44 PM
brad1964's Avatar
brad1964
I am ordering a Blueprint engine 383cid. 405hp and 440lbs/ft of torque.
Old May 26, 2013 | 03:08 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Why?
Old May 28, 2013 | 10:42 AM
brad1964's Avatar
brad1964
Why? I guess it is the best engine for me and I have a couple of buddies that have used them with good reviews. What do you suggest 63mako?
Old May 28, 2013 | 11:26 AM
qwank's Avatar
qwank
does blue print offer roller cams? I don't think they did when I looked at the site.
I'd go with a ZZ383 or a ZZ4
Old May 28, 2013 | 12:05 PM
jb78L-82's Avatar
jb78L-82
Crate engines like the ZZ4, not originally installed in a GM vehicle, like the crate engined LS7, are rated at GROSS HP/TORQUE, NOT NET HP, like production engines today.
A crate ZZ4 engine probably has around 290-300 NET HP, at best. As an example, the 71 LT-1 rated at 330 Gross HP in 1971, was rated at 255 Net HP in 1972-same exact motor with the 2 different rating systems.
Old May 28, 2013 | 12:32 PM
morleyz's Avatar
morleyz
Yes they do: http://www.blueprintengines.com/index.php/gm-383-new
Old May 28, 2013 | 12:36 PM
morleyz's Avatar
morleyz
That's what I thought too, but this has recently been confusing me. Take the LS7 for example. It's rated at 505HP as a crate, which is the HP rating as the Z06 Corvette. Shouldn't the crate be higher or the Vette lower?
Old May 28, 2013 | 01:19 PM
redwhitekat's Avatar
redwhitekat
There must be someone with a zz4 with some dyno results. Would be interesting to see what a zz4 does. As I was thinking of putting one of these in my 74 in the next couple years
Old May 28, 2013 | 03:38 PM
C3 Stroker's Avatar
C3 Stroker
Originally Posted by morleyz
........... It's rated at 505HP as a crate, which is the HP rating as the Z06 Corvette. Shouldn't the crate be higher or the Vette lower?
The crate is rated net, the same as if installed in a Vette with accessories. If it was rated the same as dyno musclecar engines (gross HP, as we are used to seeing), it would be higher...perhaps 530 HP or so.
Old May 28, 2013 | 06:23 PM
silvvette's Avatar
silvvette
IMO zz383, best bang of the buck.
Old May 28, 2013 | 06:25 PM
jb78L-82's Avatar
jb78L-82
As already stated, since the LS7 was installed in a production car, the Z06, it is rated at the NET HP rating as all production cars are, as a crate motor. Any crate motor NOT installed in a production vehicle is rated at GROSS HP, not NET. Most crate motors are rated at Gross HP since they were never installed in a production GM vehicle-a 383 for example. Hope that helps!
The point of the discussion to make folks aware that taking a ZZ4 crate engine and installing it in a C3 does not result in an instant 355HP like say a C5 corvette with 350 NET HP from the factory. They are different! Like I stated before a ZZ4 at best is probably producing around 290-300 Net HP in today's terms like today's production cars. just an FYI.
To Crate engine specs
Old May 28, 2013 | 10:29 PM
morleyz's Avatar
morleyz
I'm complete misread what you wrote the first time, but I appreciate the additional info. I'm all straight again. This thread really through me for a loop until just now.
Old May 29, 2013 | 07:58 AM
gdh's Avatar
gdh
and well put! This helps explain why so many vintage GM owners (not just vettes) have gone with the Ls swaps. They are very good bang for the buck these days.
Old May 29, 2013 | 08:52 AM
diehrd's Avatar
diehrd
Technical Notes: GM Crate Engines are horsepower rated to SAE Standards.
HP ratings are at the crank.
The SAE standards eliminated "Gross" hp results years and years ago and mandated "Net" hp. You can not use an example from 1971 to explain hp ratings of today's testing requirements.
Now lets go further , because it is made as a drop in anything pre 1985 a zz4 if configured as GM has it on the dyno with the same headers , carb and accessories it will produce the advertised power pretty closely.
Add to that the many many people who have actually run there ZZ4 on a dyno who can show a drive train loss of 15 to 20% over advertised and it pretty well confirms GM ratings as accurate.
From all my searches I have to say 355/405 at crank is an accurate HP rating not inflated by "Gross" testing standards of the long ago past.
