front sprrings rusty
Old Jun 1, 2013 | 05:50 PM
dmaxx3500's Avatar
dmaxx3500
Default front sprrings rusty
im in the middle of cleaning-up and finishing up a resto on the 69 427 tri-power vette roadster i bought,,the front coil springs have suface rust on them,im trying to get it as close as a professional resto as poss[with-out going crazy],but reading some of the under side susp parts were left bare,,,the frame is done[chassis black,the whole susp is put back together,should i dissassemble the front and rear susp to
1.blast the front coil springs?
2.blast and repaint the rear diff[its chassis black],it probubaly look better [cast iron color]?
3.the driveshaft/rear half-shafts[chassis black] should be natural grey?
should i just leave everything or just take most everything apart and do it?,,am i being to picky?
Old Jun 1, 2013 | 06:03 PM
Alan 71's Avatar
Alan 71
Hi dm,
You can be as picky as you please.
Originally all the parts you mentioned were 'natural', so they rusted.
Blasting them and leaving them natural isn't a tolerable option for most people. Everything will rust.
Some people coat the pats with semi-flat clear which gives them some protection and a somewhat original appearance.
Next would be to paint the front springs and rear differential case with something like 'cast blast'. This gives these parts a good look.
The drive shaft and half-shafts are a bit different... they have cast iron u-joint carriers which where welded to extruded steel tubes that appeared quite silver/shiny right after the were made but rusted quickly. Cast blast on the u-joint carriers and a bit of clear on wire brushed tubes looks good to many people.
The more you take apart the more detailed the results will be. If you're not going to disassemble things perhaps semi-flat black on everything is the way to go.
So it's up to you!
Regards,
Alan
Old Jun 1, 2013 | 06:49 PM
dmaxx3500's Avatar
dmaxx3500
thanks,
To front sprrings rusty
