Do Air Cleaners Make A Difference
Thanks for posting the data, but I believe that the sensor that was mounted on the outside of the CAI is too close to the valve cover for a proper reading.
It should be in a location that obtains ambient air with min heat from the engine.
The 65* reading I assume is with the engine cold.
I would be very interested of seeing the following two results.
1. Current setup with car at idle for 5 minutes.
2. Modify outside CAI sensor to be located on top of the air cleaner assembly.
I think that you could also see similar results using a IR sensor by just hitting the valve cover and the top of the carb with the engine running.
Andrew
the 69* reading is in the bowl at the same time the 111* is out side at 50mph.
the 65* in in the garage cold before test.
air from open element units pick up air right where i have the sensor,,, not on top of the unit
And I did the same with a pressure differential gauge, with a +.2 psi at 100mph
Hmmm, that is very interesting info. augiedoggy. I have a K&N filter in my 2004 Lexus RX330 and it has been in there for more than 50,000 miles as a daily driver. I don't use a drop more oil than the day I bought the vehicle. I think maybe your problem with oil consumption in your vehicle was affected by more than just the K&N filter. As mentioned it is JMHO.
Did you perform the same test using the stock air cleaner assembly.
I have a old Crown Vic as a DD. Stock hosepower is something like 210. The Mercury Marauder of the same vintage has the same engine, but has an air cleaner element/induction box that is probably twice the size of the one in my Ford, and makes about 300HP.
I currents use spectre cotton type filters in three of my rides which are basically the same thing but do so bacause none of them have the stock air intakes or cleaner assemblies to begin with and the new assemblies came with the elements I have been monitoring these very closely to make sure the cotton isn't plugged or disinigrating as I,very seen others do. My daily driver uses a stock paper element.
https://www.faasafety.gov/files/gsla...%20branded.pdf
Disreguarding humidity and barometric pressure and looking only at temperature look up 50 degrees vs 110 degrees and it's effect on density altitude.
http://www.google.com/imgres?imgurl=...QEwAg&dur=2966
If your live at 1000 feet above sea level and have a cold air intake let's assume no heating of the air on it's way to the carb for a CAI just to keep things consistant.
At 50 degrees this puts the density altitude at the carb at about 700 feet above sea level. This is where the engine thinks it's at based on temperature.
Now look up 110 degrees (a temperature easily reached under the hood of an operating C3).
At 110 the density altitude is 4,600 feet. A significant difference in the perceived altitude of operation by the engine. So the air is far less dense due to the heat. Less air = less fuel = less power potential.
To convert this to HP this formula can be applied.
HP loss= elevation X .03 X HP@ seal level/1000
First example at 50 degrees and 700 ft density alt.
HP loss=700X.03X350 HP @ sea level/1000 (just picked 350 HP for example)
This gives us a loss of 7.35 HP from a sea level rating of 350 HP or 342.65 HP a 2.1% loss of power from sea level.
In our second scenario of 110 degrees and a density alt of 4,600 feet we get this;
HP loss = 4,600X.03X350 HP @ sea level/1000 which gives us a loss of 48.3 HP or now 301.7 HP. This is a 13.8% loss of power.
So those of you who doubt 20 to 30 hp loss would be correct, it could be even more.
Keep in mind when an engine is dyno rated it is corrected to sea level at standard atmospheric conditions.
All I know is that the hood/ intake is the only modification that I've made recently and the difference from before is very noticeable, better throttle response, less hesitation, and pulls harder during wot. My engine puts out about 500hp.
While monitoring the temperature sensors, when I nail the throttle, with close to 50 degree cooler temps going into the intake than what is in the engine bay, the temperatures steadily rise in the engine bay, and steadily lower going into the air cleaner from the cold air chamber. To me it shows not only cooler air into the engine, but also a positive air flow coming into the air chamber feeding the engine. Much better than the under the hood open air cleaner that I had before.
Anybody notice a difference in performance when they drive their vette on a 100+ degree day, compared to a 50 degree day?
I'm going to get blasted for saying this but there are a lot of forums out there some seem to deal more in misconception and perception and some actually have a lot of real experience and fact finding testing done and posted by members while I applaud the member here for making a very nice modified cold air intake I believe he is greatly mistaken on his percieved HP gains. If you don't believe me look at the mustang or ls1 or hotrodders forums.... there are countless threads on this where people with time and dyno access have shown the proof and the dyno doesn't lie... k&n filters have been tested in labs and have been shown to be inferior at keeping the dust out that wears out cylinder walls.... does it destroy everyone's engines no but for the 1-2 HP the filter provides its not really worth it "IMHO"
Cold air intakes are great in theory but because of other limitations do not have 20-30 HP gains on a stock engine or any engine that had a intake / filter designed to keep up with the cfm flow of the Carb and engine. Go ahead Google " dyno results cai vs" and you'll see most don't see any change other than the normal dyno pull variances you can get without changing anything... now look at the positive CAI dyno results..... now factor out each one thats trying to market something...
I realize there may be a lot of people here with more important things in their lives than really taking the time to research something before believing it as gospel but if it were really that easy.... well you better jump on that oceanfront property in Utah.
Hold a k&n filter up to a light bulb.... it doesn't take much to see how they let so much dirt through.... lots of big holes...
In any case they would be tested on the track and not the dyno.... again questions have bee asked and results tested.... Google can be great for this stuff.
http://books.google.com/books?id=OAw...vizard&f=false
Pete
I wouldn't trust a K&N to my dirt bike, I wouldn't trust a paper element for that use either, but for a daily driver or road driven vehicle it works just fine with no ill effects thus far.
By C.J. Baker
The Banks Super Scoop, as shown on this Ford V-10 gasoline engine, provides both cool air and a mild ram-air affect. The Super Scoop also incorporates a water drain to separate any rainwater from the airflow entering the scoop.
Most people know that engines make more power when the inlet air is cooler. Let's take a look at why this is true - at least in most applications. We'll also tell you right up front that this article might leave you with more questions than answers. Then again, you might be the one that provides the additional answers and takes the world to the next generation of internal combustion engines.
To understand what goes on during both the intake cycle and the power cycle when inlet air temperature is reduced, we need to consider both normally-aspirated and supercharged gasoline engines, as well as turbocharged diesels. We'll also limit this discussion to four-cycle engines.
Before we go any further, let's define a couple of terms. For this article, we'll say that supercharging is anything that increases the amount of oxygen available in the cylinder to support combustion of fuel above what could be expected from cylinder filling due to atmospheric pressure only. We'll assume atmospheric pressure at sea level to be 14.7 PSI and that "normal" air contains approximately 21 percent oxygen. We'll also exclude oxygen-bearing fuels, such as nitromethane, as a form of supercharging. This means that any form of mechanical compressor that pumps more air into an engine, such a belt- or gear-driven "supercharger", or an exhaust- or turbine-driven "turbocharger" is included, as well as the injection of nitrous oxide, or even oxygen itself.
Gale Banks has a favorite saying, "It's all about airflow." Airflow helps engines make power in many ways, as explained in other articles on this site, but it is also true that the more air you can flow through an engine, the more oxygen that will be available for burning fuel. More oxygen means more fuel can be burned, and that means more power. Maybe his saying should be refined for this article to be "It's all about oxygen content." This is most evident when dealing with an ordinary normally-aspirated gasoline engine. Many hot rodding tricks relate to getting more air(read oxygen) into the cylinder. Whether it's by installing a less restrictive fuel injection system or carburetor, a freer flowing intake manifold, porting the cylinder head(s), increasing camshaft lift or duration, the purpose is still the same - get more oxygen into the cylinder. Now in all fairness, the hot rodder is looking at getting maximum oxygen into the cylinder at wide open throttle for peak power (to beat the other guy). This is partly why nitrous oxide (an oxygen-rich gas) injection is so effective. Nitrous oxide effectively increases the percentage of oxygen in the working fluid (which becomes a mixture of air, nitrous oxide, and fuel) above the 21 percent oxygen in air alone. That means more fuel can be mixed into the working fluid too for greater combustion heat to expand the working fluid and increase pressure in the cylinder. Additionally, when the compressed nitrous oxide, which is stored in its pressurized container as a liquid, is injected, it depressurizes and changes state from a liquid to gas, cooling the working fluid for an accompanying density increase. Of course, it would take an incredible amount of nitrous oxide to be able to use it at all times, so as you would expect, nitrous oxide injection is only used on demand at wide open throttle. But what if we could get more oxygen into the engine at all throttle positions all the time? Then what happens?
In another article on this site, "Airflow - the Secret to Making Power", we explain that the air throttle on a gasoline engine controls the density of the intake charge that enters the cylinder. We also explain how superchargers and turbochargers increase the density under boost conditions. In some regards, we can look at density as the amount of oxygen crammed into a given volume of air (the working fluid). Increased density means the molecules in the air are closer together in the same space - more air mass (and oxygen) in the same space. Here's where things can get a little muddy. We have to consider increased air density in both unconfined and confined spaces. Let's look at an unconfined space, such as the atmosphere, because that's the world of the normally-aspirated engine. Two things affect air density in the atmosphere - pressure and temperature. As atmospheric pressure goes up, indicated by higher barometric pressure on a barometer, the density increases if the temperature stays the same. In other words, at any given temperature, if the barometric pressure rises, so does the air density. By the same token, as temperature goes down, the density increases if the atmospheric pressure stays the same. Atmospheric air density is very important to normally aspirated engines. Obviously, you can't do much to increase the atmospheric air pressure in regard to a normally-aspirated engine, but you can enhance it slightly with some form of ram air taken either from the front of the vehicle or from a dynamically high pressure area, such as the base of the windshield. More importantly, in most cases you can do something about the temperature of the inlet air. The object is to get the coolest air possible to the engine's intake system. Many engines induct air that has passed through the radiator or over other warm areas of the engine, significantly heating the air and reducing its density. By relocating the air intakes to duct outside air that hasn't been warmed into the engine, density is significantly increased. For example, it is not uncommon for air to increase up to 50º F. passing through the radiator and air conditioning condenser on a late model vehicle. The general rule of thumb is that for every 10º of temperature drop, the density (and oxygen content) increases 1 percent. It's actually more like 1.8 percent. Similarly, power increases by an equal amount. So, in this example, if you can intake air that hasn't been heated, you can gain as much as 5 to 9 percent more power. Happily, the best places to collect cool air are the same places that work for ram air, so you can get the density gains from both pressure and temperature using the same intake ducting.
To get back to our earlier question of what happens when we have cooler, or higher density, air at all throttle positions, it means that the engine is capable of producing given amounts of power at lesser throttle openings. This generally equates to better fuel economy. It also means the engine has greater power potential for accelerating or climbing grades. Cooler intake air also suppresses detonation since the working fluid doesn't reach as high a temperature on the compression stroke - again, a plus for accelerating or climbing grades.
Both gasoline and diesel engines that use superchargers and turbochargers face their own unique problems with intake air temperature. Superchargers and turbochargers significantly heat the intake air as they compress it to create boost. The higher boost pressure increases the air density, but the increased temperature of the air can largely offset this density gain. In this case, we're talking about the affects of pressure and temperature in a confined space, the intake system. Consequently, it is desirable to cool the compressed air before it enters the engine. In most cases, especially where boost levels exceed 7 PSI, cooling the compressed air with a charge air cooler, often called an intercooler, increases the air density more than any density losses that occur due to the accompanying pressure drop due to cooling or flow restrictions through an intercooler. In other words, intercooling results in a net density increase for the air entering the cylinder.
Intercooling also provides other benefits. For supercharged or turbocharged gasoline engines, reducing the intake air temperature suppresses detonation, just as it does for normally-aspirated gasoline engines. For diesel engines, intercooling not only increases charge density, it also results in lower exhaust gas temperature. Excessive exhaust gas temperature, above 1300º cannot be sustained in a diesel without eventual engine and/or turbocharger failure. Lowering intake temperature results in an almost equal reduction in exhaust temperature. For example, the air exiting the turbocharger on the Banks Sidewinder pickup was approximately 500º F. under full power. Dual air-to-water marine intercoolers, connected to a reservoir of ice water, were then used to reduce the air temperature to 100º F. before it entered the engine. With the intercooling, exhaust temperatures remained manageable for the duration of the Bonneville World Speed Record runs. Without intercooling, the exhaust temps would have been in the 1800º-1900º F. range.
The final conclusion is that regardless of whether an engine is normally aspirated or supercharged, gas or diesel, the cooler the intake air, the better. Usually.
