Do Air Cleaners Make A Difference
Urgent Help Please...Need To Buy Shortly
Just wondering if anyone can help me....I've recently purchased my first Corvette...Its a 1975 Corvette Stingray Coupe Automatic T/top...It has a new Crate Motor whcih is a 350 chevy & we believe has a mild cam in it...its a 290Hp
I'm just about to change from the rochester carby to a Holley 600 & i've been told to change the intake manifold as well so i will be buying an Edelbrock Performer Intake Manifold Endurashine
Now to my questions....I have seen Standard Air Cleaners, Edelbrock Cleaners, K&N air cleaners...standard ones are cheap at around $40 where as for a K&N which are around $180...the K&N has the top as a filter as well......Is there much difference between the basic standard cheap one & the higher priced ones?....which one do you use or know is better & why?
Cheeeeeerz
Mike
I prefer the OEM paper style because I prefer the throw-away no maintenance. With the oil-lubed filters, it can become a hassle when oiling (too much vs too little, too much results in oil particles everywhere etc).
Andrew
http://forums.corvetteforum.com/c3-t...80-hood-4.html
I have a '74 which uses a low profile element. I swapped in K&N element for a '77 which is almost an inch taller (I needed to get a longer stud to hold it).
Big difference at highway speeds and above. The improvement in torque from 55 to 80 mph is delightful. Just a toe squeeze on the throttle, and you've passed that guy. Great fun.
I use a K&N on my daily driver (96 Crown Vic), as well. I noticed a nice improvement in midrange torque there, too.
I believe that its mostly because even with the hood open the stock air cleaner is pulling in cold air from in front of the radiator. Also I think the because I have a clutch fan that there might be a lot of turbulence around the open air cleaner causing it to not flow as well.
Just for fun we did a pull with no air cleaner and dropped another 15 hp from what I had with the open air cleaner. On this pull it was really rich over 4000 rpm. The dyno shop tuner told me its because of the air flow from the fan blowing over the carb.
Good luck
If you going to drive the car a lot, the K&N filter is excellent because it will get you better mpg, and better power... however, unless you're going to drive it to the million mile guarantee - I'm not sure it's worth the cost difference.
But they do look cool, and filter tops work pretty well as well...
Thankyou for your replies....iotto my rochester has a worn main shaft which my mechainc said is not worth a re-kit as better carbies are at good prices...My mechanic suggested i put a holley 600 on car & if i do its better to change with it the manifold to have a Edelbrock performer manifold..he said i would get much better throttle response/more torque etc
I tend to agree with "Gluvnaa" about the paper ones are throw away & replace as what is the correct way of oiling K&N Air Cleaners...what is too much or not enough oil,,,,but i guess it all comes down to if its worth the extra $100+ for the more expensive air cleaners???
Cheeeers
Mike
Cheeeers
Mike
That said, if it's the original 75 Quadrajet they are somewhat difficult to tune as they have a different part throttle metering setup than other years. I'd personally swap it for a 77+ M4M QuadraJet.
If the car is currently driving well, there's no reason to change. You'll have better torque and throttle response with the stock intake and carb, despite what your mechanic says. The primaries on the QJ are smaller and more efficient than those on a Holley 600.
Do you know for a fact the shaft is leaking? They are loose and do have some play.
What are your symptoms?
On that engine, I doubt adding a performer intake would gain you much other than a little bling.
Its your car so at the end of the day your decision....just trying to save you a few $$$
And Mike, any pics of that residence, Im interested!
The 1963 Corvette air cleaner comes to mind on this issue. If you recall, it has two tapered snouts that provided no more opening to air than the size of 2 pingpong ***** (or golf *****). Compared to the size of the air filter inside the housing, they looked TINY. But, I've been told that those restrictions, followed by those tapered inlet tubes actually caused the air velocity at the filter to be increased! Thus, that air cleaner provided allowed better engine performance than an open element cleaner would do.
Chevy Engineering did a lot of testing and evaluation of all its product designs. I can't imagine them putting that crazy air cleaner on that engine if it didn't out-perform an open element design.
Bottom line: Don't swallow all the hype on high $$$ 'gadgets' for your car. If you want to spend big money on "stuff", you need to have some evidence that such items really do improve something before dumping cash on them.
P.S. Repairing a throttle shaft bore on a usable Q-Jet is MUCH less expensive than buying a new carb. You will not improve engine performance by switching to a Holley. And, if you want to see if the "loose throttle shaft" is significantly sucking air, just plumb a vacuum gauge into your intake manifold vacuum connection and take a reading when the engine is idling. Then pack a little clay or Play-Doh around the ends of the throttle shaft(s) at the [supposed] "gaps" between the housing and shafts. Read the gauge again. If there is little [or no] difference in readings, the shaft isn't really that worn. Not to mention that such a vacuum leak would only affect the carb during an idle condition. Once the carb starts to open, any piddly amount of leakage at the throttle shafts would be incidental.
Cheeeeeerz
Mike
Hi Mike,
I went with the Moroso 14" low profile drop base racing air cleaner.
Along with my Weiand x-celerator intake manifold and Quick Fuel 750SS carb, everything fits under the stock hood nicely.
Incidentally, if you are going to change out the intake manifold, I would consider a Weiand Team G or Edelbrock Victor Jr instead of the Performer intake. Both will provide more HP and TQ and have low carb mounting pads. I recently read an article in one of the performance magazines which did an in depth test of many small block chevy intake manifolds, in the tests they found the Weiand Team G and Edelbrock Victor Jr to be amongst the best and they were also amongst the lowest height intakes available.
I've also recently purchased a 14"X3" K&N air filter element to replace the paper element. I've used K&N filters on my daily drivers and found them to be an good addition to provide additional air flow.
There have been tests done on the air cleaner style and the K&N filter element that suggest that both have benefits compared to the standard air filter and element.
Besides, having the stock 77 air cleaner on my new engine just didn't look correct. JMHO.
Understanding.... i'm no where near the knowledge of a mechanic
....my car was at the workshop & was running rough which the mechanic said was not the Msd ignition or leads....He leaned over & grabbed the side of the carby which he said was the main shaft & wiggled it a little & the engine was revving up & down off of idle...this is how he told me the shaft was worn, he mentioned it seems to have been re-kitted before & was best to replace with a holley600......Replies are welcome
Cheeeerz
Mike
