I agree. The old style seals were known for leaking quite a bit (if that is what the rebuilder used). If is a valve stem seal(s) that are leaking you should see a few seconds of blue exhaust on cold startup. GM came out with a much better Viton seal in the '80s I think. Or one may have failed. Changing out the seals is not a big or expensive job. With that much crud on the bad plug the rings may be crudded-up by now. An old school trick is to add water (slowly, but as much as you can w/o stalling it out) while holding it at 2500 rpm. A plastic squeeze bottle works great for this. Steam cleans the top end andmaybe would de-gunk the rings.
Worked great for me many, many moons ago.
I'll be looking for smoke when we get it on the road. We (and by we I mean my husband) still have to figure out what's draining the battery first.
The water trick sounds good, how much water should I use?
I had a 500 mL squeeze bottle. Mayhave done it more than once, can't remember. GM used to sell a top end cleaner that you applied by the same principle but you were supposed to let it sit for 20 minutes after applicatiion (final stall out). Sharpened up the 'perf' quite well. Never pulled a plug, just used the stuff ..... and both methods worked. Lots of sheet blew out the exhaust .........
Go to Princess Auto. Cheap. I also had an electrical drain. I put one of these on and the drain disappeared !. Coincidence only I'm sure. I only disconnect it now when I'm doiing work on the car. Love it.
That much oil on the plugs I'd recommend 1) Sea Foam 1st (cheap) and 2) valve seals (probably needed) If it puffs blue with first start-up , yup you need to change 'em.
The pic of the second plug just looks like old plugs to me. You can get plug wires from rockauto for a good price. Like your husband said, change the plugs and wires and run the car.
Some of these guys in my opinion go way overboard. I've made my living as a mechanic for over 35 years and the first rule of thumb is to keep it simple......
Change the plugs and wires, run it and if it's running good, run it for 500 miles or so and check the plug that was worst last time and go from there.
Great suggestion, I'm going to check it out.
Originally Posted by sstocker31
I agree with 7T1vette.....but look after yourself first and get that dental work done, then change the plug wires....keep the priorities straight.
Thanks for the advice. I don't think the husband feels the same way I do, he's more of a "Pull it out if its a problem" type of guy rather than spending a lot more money to fix it.
Thanks Pete. Hubby thinks it might be the horn relay because when we first put the battery into it the horn wouldn't stop honking and we had to disconnect the horn to stop it.
Just an update on the battery drain problem. It turned out that my aftermarket alarm system had failed and was holding the horn relay on. Hubby removed the faulty alarm system and the battery drain is gone.
Well done!
Good for you!
A battery disconnect is good but removing the short is always best.
