new door panel fit
Old Jun 26, 2013 | 08:00 AM
1971LS5's Avatar
1971LS5
6th Gear
Default new door panel fit
How much pressure should I have to put on the door panel to get the window crank to go on. Seems like the panel does not have the right curve to let the crank all the way on, and yes it is touching all around the edges with the snap clips connected. Thanks
Old Jun 26, 2013 | 09:24 PM
77SHARK*'s Avatar
77SHARK*
Cruising
My new panels didn't fit like the originals either. I had to take a little off around the door handle and the lock **** with a dremel tool to get the one on driver's side to work. I have power windows so I didn't have to deal with the window crank.
