81 computer. cam suggestions?
You would accually want to go to Dome Pistions to increase compression with stock heads but you will have to do the research some require boring the piston walls
The L48 engines are able to be modified but going into high compression they need the 4 bolt main of the L82 engines.
http://www.summitracing.com/search?k...0pistons&dds=1
http://www.summitracing.com/parts/cro-00462/overview/
or like an xe262h or the 4x4 X4262h? the only difference between these two is higher exhaust lift ijust need a little bit of cam music out of it or im going to feel like im wronging this vette build.
I'd also keep duration under 220, especially if you're not raising the CR. Try to get CR to at least 9:1.
If you're sticking with stock heads, don't worry about a 4 bolt main. The 2 bolt will hold up just fine. This thing will likely not pull much past 5k anyways.
http://www.summitracing.com/parts/sum-k1102/overview/
It won't be a dragstrip terror, but it should at least be able to get out of it's own way. You could maybe even go up to the k1103 cam, it's just big enough to give a little rumpity-rump to the idle, I don't know if the computer would like it, though.
Scott
im going to run it with flat tops. I wish I felt comfortable with dome pistons but I just don't care for the flame travel efficiency of dome pistons. iv always just used good heads except im not allowed to on this build. what kind of a cam runs less than 220 duration?
Scott
I realize this car wont be all that spunky especially with the auto but I just would like to get a little sound if not something different for the guy as he is on dialysis and has a broken leg currently.
I appreciate the responses I just personally feel the most comfortable with the comp line
You can put a giant cam in if you want, but you're limited to the stock heads so there's not a lot of point. I'd go with the K1102 Scotty recommended.
If you were going up on heads and intake, along with static CR, I'd say to go up more on cam. Throwing a big cam at heads that can't support it is a recipe for disappointment.
If you can get the XE262H ground on a 112LSA you'd probably be OK. I'd rather run a smaller cam given the heads frankly suck.
mild ford cams and mild chevy cams must be different. I run a cam in my 289 with 11 to1 at something like 498 lift. iv always considered this mild.
im obviously chevy ignorant. I didn't think the cams I listed were big enough to bleed off enough compression at low rpm to be a problem.
if neither of these cams have a chance at working I guess il just go with the stock cam as id rather be sure it runs well since the vette engine bay is pretty tight and id rather not have to change things.
You can also have the heads milled to reduce the size of the combustion chambers.
DC
What you must understand is that he doesn't really care about power...he wants his engine refreshed. Why not try to do what he wants for his car so that he will be pleased with it?
And yes, as mentioned you could port the heads and that would help a little.
These engines are actually quite fun with the stock heads and cam, as long as they're in good tune. Around town they scoot pretty well, they just run out of steam around 3500-4k.
7T1Vette's point is pretty spot on as well.
Why in God's name is anybody letting you rebuild their engine?
-TJ
Yes, your 11:1 289 is going to like a big cam. An 8:1 350 will not, especially with the 2.87 diff gear and the stock converter. And, too big of a cam will make the crude, ancient computer puke. It only has Read Only Memory, you can't program it. You have to deal with it's parameters, or chuck it, one or the other. Also, IMHO, a Comp Cams cam is a waste of money on a build at this level, the summit K1102 will do just fine, and save some coin.
So, here's my advice: flat top pistons, Summit k1102 cam, pocket port the stock heads. Take it or leave it. If the guy complains that it doesn't make that much more power, say "I tried, but you wouldn't let me."
Have you thought about just telling the guy that the heads are cracked between the middle exhaust ports, and he needs new ones? I know, I know, it's dishonest, but ya know, the greater good, and all that?
Scott
anywho thanks for the replies. I ended up going with flat top pistons and the stock cam is being sent with the kit but I plan to upgrade it.
im not trying to do anything he didn't want. originally he told me he wanted 300 ponies out of it, but obviously he is dreaming with this stock head design and with keeping the system. . .
like everything in life, you get what you pay for.
The 383 Stroker Kits are from different manufactures and can be priced from between $600 to $1000 bucks depending on the kit and who is the manufacture.
