Be careful with how you mark the distributor. I recently pulled my distributor and disassembled it for internal cleaning and shimming the end play. I carefully marked the intake and distributor with a permanent magic marker. Before I reinstalled, I decided to clean the outside of the distributor housing and completely cleaned off all of my marks. Fortunately, I had taken some photos and, because I had just removed it, still remembered the orientation.
I do this so I have a rough base line and don't have to take the motor to TDC. I spin the motor till the rotor tip is pointing at the firewall and then put some tape in the approximate direction on the firewall, drop a straight edge between and mark. You can mark the distributor's base relationship to the intake, but like others have said you will likely lose that calibration if they clean the housing.
Any rotation of the engine will negate any orientation marks on the dizzy. Well, you can put it back in that spot, but it won't guarantee that it will be oriented properly. If the engine was not going to be changed (in any way), then, you could mark the position of the rotor relative to the dist. body AND mark the position of the distributor body to the intake. If you then remove the dizzy exactly the same way you took it out, it SHOULD install properly. But, you never know....
If the engine is rotated at all, just forget any orientation marks. Position the crank at TDC for #1 cylinder (on the 'compression' stroke, not the exhaust stroke), set the dizzy rotor so that the contact is pointing to the cap plug with the #1 wire in it (then put a big strip of duct tape from dizzy body up & over the rotor and back to hold that position), note the orientation of the drive pin in the bottom of the dizzy shaft and use a long screwdriver to rotate the oil pump shaft to approximately the same alignment, and drop the dizzy in. Don't forget that the gear is a helical gear and the dizzy will rotate some as it drops into position. So you have to 'lead' it a bit so that it will be in proper position after it completely drops into place.
And, if you don't get it on the first try, just have fun with "Go Fish!"
DC
Thanks, so the ditsy rebuild should not mess up orientation and marks?
Thanks so, disty rebuild should not mess up marks and orientation?
You're assuming that the distributor is currently installed and clocked correctly. Most are not. By marking and installing it the same way, you're going to duplicate all errors on the current installation. Just bring the engine up to 12 degrees before TDC on the #1 compression stroke (this will have the rotor pointing towards whatever cap tower you are using as #1 plug wire) and yank the distributor out. If I'm the one doing the rebuild, you'll get a complete installation instruction sheet for re-installing it correctly.
Lars
You are probably are the one that will be doing the rebuild. Tdc just sort of scares me. The car is running great now and is timed and dwelled correctly. I feel lot better if I could do marking, send to you for rebuild, and the reinstall according to markings. Thanks
It's not a lot of effort to get it set up correctly. Pull off the #1 plug, set your finger on the hole and rotate the engine until you feel pressure on your finger. Verify that the timing mark on the balancer is pointed near 0 on the timing mark.
No reason to be scared of TDC. It's not a perfect science and you'll be able to correct it after the distributor is installed, as long as you're close. (IE, the rotor tip points roughly towards the #1 cap)
DC
This is what I do when I pull my distributor, to make it even easier, line it up with some thing on the fire wall and then take a photo of it.
good luck.
I think you'd be better off educating yourself about the mechanics behind the distributor, cam and crankshaft relationship. It's not rocket science and will take all the scary out of the exercise.
Mike has a point. This is your opportunity to learn how to do it. You will feel great satisfaction after it's done, and done right. Go for it. Oh yeah, all these gurus, including Mike and Lars, were not exactly stabbing distributors out of the cradle...
I'm baffled... what's difficult or scary about bringing the engine up on TDC? Being timed and dwelled correctly now is meaningless and irrelevant - you're going to have to re-time it after a distributor removal/rebuild no matter how well you mark it, and the dwell is going to be re-set anyway.
Lars
Just never done it and I hear tdc can be challenging.
TDC for Dummies:
1) Pull #1 spark plug, which is engine front, driver side..
2) Hold finger over spark plug hole.
3) Have wifey click key (small clicks, on and off), you will feel pressure against finger.
4) Stop before damper mark approaches zero mark on timing tab.
