Failed VA State Inspection - Light Bulb Issue
Old Jul 2, 2013 | 07:46 AM
75_Stinger's Avatar
75_Stinger
Originally Posted by USAF
Put on your USMC shirt
Get out the Afghanistan hat.
Go back.
You'll pass.
The light is a judgment call.
USAF
I did that this weekend, I had my "I Believe in Heros" Wounded Warrior shirt on with my digital camo and subdued flag ball cap on.....didn't help.
The inspector I found last night was much more understanding, he looked at the bulb issue as "its a classic car, its not going to be perfect."
I am good until next July now.
Old Jul 2, 2013 | 08:42 AM
noonie's Avatar
noonie
Above the muffler on the driver's side on the corner of the frame is the ground location for the rear harness.
Remove it, clean and reinstall with some die electric grease.
If that doesn't help and the contacts in the bulb sockets are clean, then just replace the sockets, they corrode internally. Just a few bucks at any parts store.
If replacing, best to solder and shrink wrap connections.
If the lights don't work properly, it's just an invitation to get pulled over.
Old Jul 2, 2013 | 08:56 AM
75_Stinger's Avatar
75_Stinger
Thanks for the tip noonie, luckily I can cycle the blinker manually until I get a handle on the grounding issue.
