Failed VA State Inspection - Light Bulb Issue
Old Jul 1, 2013 | 10:25 AM
75_Stinger's Avatar
75_Stinger
Default Failed VA State Inspection - Light Bulb Issue
After 6 months of waiting to finally get back from Afghanistan and get my trailing arm replaced, my car back is finally back on the road, BUT that was short lived as it failed the VA State inspection.
The passenger side tail bulb does not illuminate enough when applying the brakes when the lights are on. The inspection tech said both filaments in the bulb are active when the lights are on. Has anyone had this issue? The tech suggested it is a wiring issue, the car passed inspection last year, I think he is just being too overly critical of a minor issue with a classic car.
When I apply the brakes the light does illuminate a tad bit more, it is just not as apparent on the right side as the left.
Old Jul 1, 2013 | 10:31 AM
AirborneSilva's Avatar
AirborneSilva
Glad I don't live in Va anymore! Mine on my right wouldn't light up real bright so I pulled the lens and found that the bulb socket had slipped out so the light was only about half way in the tail light lens, if that makes sense...
Old Jul 1, 2013 | 10:55 AM
MelWff's Avatar
MelWff
check the ground connection for rust
Old Jul 1, 2013 | 11:07 AM
Jig A Low's Avatar
Jig A Low
register it as an antique and avoid all the hassles, but, it does sound like a ground issue.
Old Jul 1, 2013 | 11:08 AM
1Fordman's Avatar
1Fordman
I agree, had the same problem on the 68. It was a poor connection where the ground lead attaches to the lamp housing.
Old Jul 1, 2013 | 11:11 AM
75_Stinger's Avatar
75_Stinger
I'll pull it out and try to clean the connections and leads.....hopefully that works. I think I'm going to try a run of the mill gas station to get it inspected next time.
Old Jul 1, 2013 | 11:19 AM
75_Stinger's Avatar
75_Stinger
I thought about the antique plate route, I thought with antique plates you could only drive around 1200 miles a year.
Old Jul 1, 2013 | 11:44 AM
7t9l82's Avatar
7t9l82
how do they know how many miles you drive? i used to live in fairfax county and dealt with this crap used to be every 6 months, now i guess its yearly. the problem was finding an inspector with some intelligence. few good places. i agree though, likely a ground issue. heck add a ground to the taillights.
Old Jul 1, 2013 | 11:49 AM
AirborneSilva
Here's the VA website http://www.dmv.virginia.gov/vehicles/#antique.asp
Old Jul 1, 2013 | 11:52 AM
72C3Vette's Avatar
72C3Vette
I live in VA as well, best to do antique. You just can't drive it as a daily driver, you technically are only suppose to go back and forth to car shows, repair shops, etc and minimal personal driving.
Old Jul 1, 2013 | 12:00 PM
Jig A Low's Avatar
Jig A Low
kind of hard for them to tell if you use it every day unless, the same cop see's you everyday, but unless your car is VERY memorable, I doubt they'd pay much attention to you.
Old Jul 1, 2013 | 12:10 PM
75_Stinger's Avatar
75_Stinger
My car does get alot of attention everywhere it goes. I will take a look at the ground, clean the terminals and hope for the best.
I am probably going to sell the car in the fall (I have a baby on the way), will antique plates help or hinder a possible sale?
Old Jul 1, 2013 | 12:34 PM
Jig A Low's Avatar
Jig A Low
I doubt the plates would have an impact, but, not having an inspection may, most people aren't familiar with cars and assume that if it has a valid inspection it MUST be in good shape---and converesly, if it doesn't have one, there HAS to be something wrong with it.
if you get lucky and find someone who knows cars and more importantly, corvettes it probably won't hurt ya.
Old Jul 1, 2013 | 12:42 PM
7T1vette's Avatar
7T1vette
Bad ground if the bulb doesn't provide much light. You may also want to check if the bulb is installed 180 degrees out from how it should be installed. If I remember correctly, that is a bayonet type bulb with two pins protruding from the sides. But, the [height] positioning of the pins is different. Put it in the wrong way and it won't work properly. So, try inserting it the other way.
Old Jul 1, 2013 | 07:13 PM
John A F's Avatar
John A F
Yeah, bad ground/electrical connection somewhere. Check the bulb socket contacts for corrosion. Also check the corresponding contacts on the end of the bulb. And thank you for your military service.
Old Jul 1, 2013 | 08:38 PM
C3 4ME's Avatar
C3 4ME
I too would do antique plates on it. I've got them on my 79. There's no milieage restriction, but as stated above, you're restricted in the usage of the car. It's never been an issue to me.
Old Jul 1, 2013 | 09:12 PM
jnealg's Avatar
jnealg
hey 75_stinger
when you pull your lights give the wires a little tug at the bulb socket. I found one of mine (with the same issue) was corroded inside the socket and when I tugged on it it just pulled right out.
New socket and all was well.
I agree its got to be a ground somewhere.
To Failed VA State Inspection - Light Bulb Issue
Old Jul 2, 2013 | 06:43 AM
75_Stinger's Avatar
75_Stinger
Thanks for all the tips, I did find a more understanding inspector yesterday and he passed the car. I did identify the issue though, two of them actually.
When I turn the lights on, it shorts out the radio for a second. Also, both turn signals work just fine when the headlights are off, but when the headlights are on, the right turn signal will activate and just stay on, it won't blink.......I am a little stumped.
I pulled the bulb, the leads and connections are clean and rust free, the bulb is in the correct position, anyone know what the issue could be?
Old Jul 2, 2013 | 07:37 AM
johnmb's Avatar
johnmb
I think GROUNDING might be a good place to start !
Old Jul 2, 2013 | 07:40 AM
USAF's Avatar
USAF
Put on your USMC shirt
Get out the Afghanistan hat.
Go back.
You'll pass.
The light is a judgment call.
USAF
