voltage regulator failure
Old Jul 6, 2013 | 02:40 PM
loflite's Avatar
loflite
Default voltage regulator failure
What would cause a voltage regulator to fail. I have a '76 and the regulator seems to fail on a regular basis. ( every other year). I have the best luck with new alternators as they last 4-5 years, but a rebuilt only goes 1-2 years. Any ideas?
thanks,
Old Jul 6, 2013 | 02:50 PM
oldalaskaman's Avatar
oldalaskaman
over charging all the time, dirty ground
Old Jul 6, 2013 | 06:25 PM
7T1vette's Avatar
7T1vette
'Dirty' ground, bad wiring, improperly wired, etc, etc.
Measure the battery voltage with engine OFF; now start the car and measure again; as the car becomes fully charged (voltage slowly drops and becomes stable) measure it again.
The battery voltage when the engine is just started should be near 14 volts (or maybe a bit more). After a short time, the voltage should begin to drop. When battery is fully charged, voltage should be a bit under 13 volts.
If the voltage doesn't drop as expected, something is wrong with the wiring....or your battery is approaching the end of its useful life.
Old Jul 7, 2013 | 02:15 AM
noonie's Avatar
noonie
They really aren't meant to charge a depleted battery all the time, just to keep it up from vehicle draw.
Igniton and and low speed fan will have it charging 10-15 amps while the car is running on a fully charged battery. If more at idle, then your battery/connections are suspect.
Most regulators run at 14.7 vdc max and 14.2vdc min and 80% of rated output at max rpm.
Old Jul 7, 2013 | 11:05 PM
loflite's Avatar
loflite
thanks for all the info. Will check ground connections for sure.
To voltage regulator failure
