'71 door ajar switch replacement
Old Jul 19, 2013 | 02:23 AM
StingrayLust's Avatar
StingrayLust
Default '71 door ajar switch replacement
In my previous thread, I was discussing, IMHO, the poor design of the switch. I basically don't trust that little finger to not slip off the plastic and now my switch doesn't work any more.
So last year I tried some crude experiments with my switch, one of which ended up with me taking some nails and fabricating my own connector that go through that white plastic piece on the switch. It worked for a while and then failed, it wasn't a pretty piece of work as shown here:
So with my switch not working, it was always in the back of my mind that my center console light wouldn't come on. Not a big deal really, but I want everything to work on my car. So I ordered up some more switches from Lectric Limited and one other Corvette specialty place. The LL and 'vette vendor switch appear similar but there are subtle differences as can be seen here:
Notably the LL version has the correct XS (or is it SX) stamping:
also note the slight length difference and the top is round vs flat:
I also ordered 2 sets of the 6 connectors so that I had plenty to work with in case I screwed up:
I did on mockup with 2 of the connectors to make sure that bending the tabs on the *outside* would still fit through the hole, it did:
So I got going on my electrical by soldering in some new lines and fishing them through the hole:
Previously I had used the square 1/4" quick disconnects, but had a tough time fitting them through the hole. So this time I went with some round versions of the snap connects:
So I soldered up my tab connectors...
...and bent the tabs so they would fit through the white plastic holes...
...they did. So I bent the tabs over nice and snug. You can't bend that metal too much or it will easily snap!
Then I just had to button it up:
Woohoo, now I've got a functioning "Door Ajar" light! Small miracles keep the motivation high.
So you ask "Why use the snap disconnects at all?". Good question and my answer is that if I ever have to do this again, I want to make sure that it can be easily disconnected from the wire to work on it.
Old Jul 19, 2013 | 09:02 AM
John 65's Avatar
John 65
Nice job and pics.
My only question is are you sure those tabs get bent like in the next to last pic? I thought they just push in and snap into position when they pop out the other side. Either way glad you are up and running.
Old Jul 19, 2013 | 10:11 AM
StingrayLust
Default They're not
Originally Posted by John 65
Nice job and pics.
You're absolutely correct, they aren't supposed to go in like that. Look at my original thread I posted as the start of this thread, maybe that will help understand my frustration with these things.
I just got fed up with the way the tab never caught like it should have when it's used as it should be with the metal tab popping open inside the white plastic container to prevent it coming out further. It always seemed that it was too easy to pull out. So hence why I made damn sure that it's not going to come out now!
Old Jul 19, 2013 | 01:04 PM
Griff2002's Avatar
Griff2002
I may be doing this job in the near future. Right now there is just a hole where the switch belongs. The wires are probably just sitting behind the hole somewhere. Can you elaborate on how you got to the original wires and "fished" them through the hole?
Old Jul 19, 2013 | 01:21 PM
StingrayLust
It's quite easy. Just remove the rear quarter panel and the wires feed in from the inside just behind that panel. I used a metal flag marker I had laying around to fish the wire through the inside to outside holes to make the connection.
Question though, are your rivets around the switch hole still in place? If not, the metal bracket that the switch goes into has probably fallen in the space behind the opening. It can be tough to get back at that piece.
Old Jul 19, 2013 | 02:37 PM
Sully1882's Avatar
Sully1882
wonderful work and thank you for the pics... im gonna do this with mine this weekend!
Sully
Old Jul 19, 2013 | 03:28 PM
Dave J's Avatar
Dave J
Very nice! Subscription added and saved for my to do list, which just keeps growing. Good work.....
Old Jul 19, 2013 | 06:23 PM
Griff2002's Avatar
Griff2002
Fortunately the rivets are still there. Now that I've seen your helpful instructions I'm going to add this project to my list.
Old Jul 19, 2013 | 08:41 PM
BBCorv70's Avatar
BBCorv70
How did the shafts of the Lectric Limited and Vendor's switches comapre? I've had bad luck with the vendor switches, the shafts bend easily.
Old Jul 20, 2013 | 12:36 AM
StingrayLust
It's kind of funny you mentioned this. I had quite a while ago fixed it once, and then while doing my interior work had caught some clothing on it and bent it. So that lead to my previous hack before I just fixed it right again just now.
I wouldn't expect the LL switch to withstand a whole lot more pressure before bending, but I do think it's a more quality switch. That said, I had bought 2 of the LL switches. One of them the metal interior shaft that connects to the white plastic piece has sort of a rough surface on it for lack of a better word. What I mean is that when I push the plunger down, there are times it seems to catch the bottom metal lip on the shaft causing a brief moment of extra force needed. Luckily only 1 of the 2 LL switches was really bad. The 3rd party generic switch exhibited none of those rough shaft problems. I'd be worried that if it caught hard enough, over time that it might break off my rivets caused by that repeated stress.
I had tried to sand that shaft down but I guess I failed as it didn't seem to clear up the issue. I'd order 2 of the LL switches to be safe and then post on here your experiences. If I could marry the 2 switches together, the LL and the generic one, taking the best from each I'd have a perfect switch. Close but no cigar, ahh the life of a Corvette restorer.
The SX stamping I believe is supposed to be correct if you're into the NCRS stuff.
Old Sep 7, 2013 | 04:57 PM
Griff2002's Avatar
Griff2002
Is there a trick to getting the switch screwed into the backing plate? The plate is till riveted in, but I cant seem to get the switch to take hold. It's almost like I am cross threading it, because I get resistance on the wrench, but then it gets loose. The other weird thing is I can't get the switch back out. I can pull the threaded part out of the hole by pulling on the shaft, but the plastic part with the terminals won't come out with it. It's like they are hanging up behind the backing plate. The good news is that the door ajar light I working now! I just don't have the switch bolted in right (bubba?). Next up is the passenger side, which should be more straight forward as the old switch is still bolted in, and hopefully the wires are still there behind the panel.
Old Sep 8, 2013 | 08:34 AM
c69vete's Avatar
c69vete
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
The carbon steel backing plates are now being reproduced to aid in this repair. My guess is that the threads in the original plate have rusted away, thus preventing you from screwing in the switch properly.
When I had my car painted, I made the plates out of Stainless Steel pop riveted them in. The switch threads are 3/8-16 UNC.
I could not dig out the old plates after they dropped into the abyss behind the panel, so I just let them stay burried there
Old Sep 8, 2013 | 01:20 PM
Griff2002's Avatar
Griff2002
Thanks. I've been thinking and suspect one side of the plate is loose so that I can't get the plate and switch lined up in the same plane. I guess it was too much to hope for that this would be easy.
Old Jul 27, 2019 | 08:55 PM
Bigt232's Avatar
Bigt232
Cruising
Bigt232 , I have a 73 and am starting on the door switches also. Anyone know what gauge wire was used as i plan to solder my terminals also. Thanks Tyler
To '71 door ajar switch replacement
