Power Steering Leak
Old Jul 28, 2013 | 03:36 PM
BPHORSEGUY's Avatar
BPHORSEGUY
From: SUFFIELD CT USA 2023 C8 CORVETTE UN-MODIFIED FINALIST
Default Power Steering Leak
My '77 is leaking power steering fluid. It seems to be coming from the control
valve ( assist ) unit which goes to the cylinder. The boot which is on the other side from the grease fitting looks like it has seen better days and is my prime suspect. I cleaned all of the hoses and they are still dry 2 days later despite having leaked about a teaspoonful of fluid. Some days it does not leak at all but now that I have pumped more fresh grease in to the unit it appears the leak has doubled. Does anyone have any experience with this, I have a new boot and hoses on order but I don't think I'll need the hoses!
Old Jul 28, 2013 | 04:18 PM
birdsmith's Avatar
birdsmith
I rebuilt my control valve a long time ago and haven't had any problem since, so at least in my own experience the valves respond well to rebuilding. I also replaced the hoses at the same time, and the flexible high-pressure hose started cracking and leaking about three years ago. The hose was made by Goodyear, so apparently they don't last near as long ad the OE hoses, which weren't leaking before I replaced them.
Old Jul 28, 2013 | 04:37 PM
BPHORSEGUY's Avatar
BPHORSEGUY
Bird thanks for your response, that gives me another reason to try and retain the original hoses!
Old Jul 28, 2013 | 05:27 PM
mikejpss's Avatar
mikejpss
From: Where it's always hot as Hell-South Louisiana.
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
I rebuilt my unit on my 80 model. Think I bought the rebuild parts at Wilcox ? The parts are like $40 and have instructions with it. Simple, easy 2 hour job including a beer break. !
Old Jul 28, 2013 | 05:35 PM
7T1vette's Avatar
7T1vette
The boot is just a dust/dirt guard; it doesn't seal anything. But, oil could be leaking from a seal inside at that area. If the valve is actually leaking, you will have to remove it and rebuild it. I highly recommend that you rebuild it rather than buying another 'rebuilt' unit. At least, you know that yours WAS working when you removed it. Lots of bad rebuilt stuff, these days.
The most likely place for leaks is from the hoses or hose ends/connectors. You can replace the hoses without rebuilding the C/V, but if you get into it that far, I suggest that you do rebuild the C/V and put a new seal set in the 'rod' end of the assist cylinder. Both are easy to do and the P/S will be in good shape for many years to come.
Be advised that you should examine the oil and make sure it is P/S fluid before you tear into it. Valve covers, hoses, filter are all above that area and can leak down onto it. So, make sure of the leak source before you "fix" it. Good luck!
Old Jul 28, 2013 | 07:29 PM
BPHORSEGUY's Avatar
BPHORSEGUY
Are these o-ring type seals?
Old Jul 28, 2013 | 07:49 PM
mds3013's Avatar
mds3013
The seals in the valve are lip seals like in a master cylinder on your brakes. There is one o-ring if I remember correctly. Check this out. Close to the bottom of the page you will find Jim's rebuild papers for the control valve. mike...
http://jimshea.corvettefaq.com/?cat=5
http://willcoxcorvette.com/product_i...oducts_id=1014
Old Jul 28, 2013 | 09:11 PM
BPHORSEGUY's Avatar
BPHORSEGUY
Gentlemen thanks for your help, I may have been going in the wrong direction!
To Power Steering Leak
