Fan Wiring
We are thinking that we need to wire the fan to the thermostat and/or engine somehow. Any ideas out there. Really appreciate your input.
what you need do is get an early a/c blower relay like on your car, with a pigtail, run a 30 amp fuse from one side of the contacts to the stud on the alternator output, NOT TO THE BATTERY CABLE.....then the other relay contact to the fans + fans - goes to frame/engine ground, obviously.....one side of the relay coil goes to a switched hot, such as the yellow wire on the wiper motor, other side of coil goes to whatever controller you want, computer, thermo switch, anything that will ground that end of the coil thereby closing the power contacts....
NOW if you have a/c you need put another relay in there to close/activate the fans when the a/c is on, regardless of engine temps....it be activated when the compressor clutch is energized.....
I have a FI setup on my car, so the computer takes care of fan operation....
