Engine Block "V" designation
Old Jul 28, 2013 | 05:08 PM
loghomesutah's Avatar
loghomesutah
2nd Gear
Default Engine Block "V" designation
I have an engine block in a 1972 corvette that has the designation V0515.
I understand that the 05 is the month? However, I am unsure what the V designation means.
Mike
Old Jul 28, 2013 | 05:20 PM
gcusmano74's Avatar
gcusmano74
I think the "V" is the code for the engine assembly plant. In your case, Flint, Michigan.
Old Jul 28, 2013 | 05:23 PM
restoman1's Avatar
restoman1
Yep. V0515 would be the assembly plant (V = Flint, MI), the month (05 = May) and the day (15 = the 15th). There will be two letters after that which will tell you the engine designation.
Ed
Old Jul 28, 2013 | 05:27 PM
loghomesutah
2nd Gear
Ed
Thanks Ed.
I was under the impression that "F" refers to Flint, MI and "T" refers to Tonawanda, NY I got this from "VetteFacts.com." However, they may have it wrong or --- F or V refers to Flint, MI.
Mike
Old Jul 28, 2013 | 05:33 PM
restoman1's Avatar
restoman1
F did refer to Flint through the 1966 model year. From 1967 on, they went to the V designation (for V8's. L6's still used the F designation). And yes, T is Tonawanda.
Ed
Old Jul 28, 2013 | 07:07 PM
Mike Ward's Avatar
Mike Ward
Ed
and K (not seen on original Corvettes) is for the McKinnon Industries engine plant in St. Catherines Ontario.
To Engine Block "V" designation
