Performance Problems on 81
Old Jul 30, 2013 | 06:09 PM
mcnees's Avatar
mcnees
Navigator
Default Performance Problems on 81
I have an 81 vette that when it gets warm it runs like crap. We have replaced the exhaust, carburetor, fuel pump, timing chain and still after running for about an hour it suddenly runs terrible. When it is cold it runs great but after shutting the engine off and starting it when it is hot it will hardly run. Any suggestions?
Old Jul 30, 2013 | 06:45 PM
DUB's Avatar
DUB
Need much more descriptive information. You are leaving too many un-answered questions.
What type of carb???
What type of exhaust...and is the engine still needing the computer to run it...such as an O2 sensor in the exhaust...the TPS an mixture control solenoid in the crab??? Headers??? If you installed these new...you can run into severe heat issues that can effect many items if you did not take into account for this and protect items from excessive heat.
Are you using a timing light to set timing??? Do you know for a FACT that the outer ring on the balancer had not spun and you not having the timing correct???
Have you connected a scanner to the ALCL and see when the car starts running bad...has the car gone into "closed loop"??? This is important if you are still using a computer to make it run correctly.
Fuel pump??? Did you install one that still uses the fuel return line???
Like I mentioned...numerous issues that need answers to. The more detailed information you can give will be helpful.
DUB
Old Jul 30, 2013 | 06:54 PM
Shark Racer's Avatar
Shark Racer
Bad seals on the idle air bypass on an E4ME carburetor will cause all kinds of weird behavior when going open loop, however, these will appear within 10-15 minutes max.
Old Jul 30, 2013 | 07:50 PM
mcnees's Avatar
mcnees
Navigator
Thanks DUB and Shark. Dub, It has a Rochester quadrajet stock carb. The exhaust is now straight dual with no cat, stock exhaust manifolds and maganaflow mufflers. It is still on the computer and the guy that installed the mufflers said he attached everything back. My mechanic put the new timing chain on so I am not sure how he timed it. I will ask him about the scanner. The fuel pump that we replaced does have the return fuel line. I wish I could be more helpful. My mechanic is pulling his hair out trying to figure this out. Thanks again
Old Jul 30, 2013 | 08:08 PM
SIXFOOTER's Avatar
SIXFOOTER
Post a couple pics of the carb and engine bay if you can. The 81 came with an E4ME electronic carb. If its not all connected and setup correctly it will not run right. Its not hard to do, but does have to be done right.
The O2 sensor should be very close to the exhaust manifold, close to the head.
Is the GEN light indicating any kind of code?
Old Jul 30, 2013 | 08:48 PM
maxmachz's Avatar
maxmachz
1st...Choke hanging up? Check the choke cold. Take off the air cleaner, mark it's position and start it. Make sure it is functioning properly. Check engine light work?
2nd....Hot engine performance issues, if the engine is not overheating points to ignition component failure / problems. Cap, rotor, ignition module, coil....plugs, wires....as old as it is, replace that stuff 1st. Cheap and necessary tune up so you know that is all OK. Fuel filter screen in the carb inlet, and the inline under the chassis.
Old Jul 31, 2013 | 03:29 PM
papapete's Avatar
papapete
I have the same problem on my 81. I replaced the coil pack cap & rotor but not the wires was thinking the carb next! I will take maxmachz's advice and try wires first.
SharkRacer where are the seals on the idle air? Will be humble myself and say I don't know what they are? Thanks in advance for any and all advice!
Old Jul 31, 2013 | 04:40 PM
7T1vette's Avatar
7T1vette
A "stock" carb for a 1981 model year C3 is NOT the same as any other Q-Jet. The '81 carb had an electronic gizmo for adjusting rate of fuel dispensed by the carb; and the computer system and O2 sensor managed that (one year only) carb and matching distributor to set the fuel flow properly.
If you still have the ECM and dizzy from the original '81 installed and operating, but have changed the carb, it is not a surprise that it runs like crap. The only surprise is that it runs like crap ONLY when it is warmed up.
If the ECM has been disconnected and the carb and dizzy are units from a year other than 1981, you will have to look to the "usual and customary" reasons for your problem. But, if you have a 'Frankenstein' combination of parts on your engine and the ECM is trying hard (but failing) to manage the timing and fuel flow, you will have to decide whether you want a 1981 induction/ignition system on your engine or you want to revert back to a 'non-electronic' system for those functions.
Old Jul 31, 2013 | 05:15 PM
wajulia's Avatar
wajulia
I am with Max -- something in the ignition circuit. Coil pack or Ignition control module is breaking down with heat.
The 81 CCC carb does not run "bad" when the computer goes open loop, it runs rich (Feul jets wide open) and slugish (default timing advance at all times). If the engine is stumbling, probably ignition
Old Aug 2, 2013 | 10:32 AM
papapete's Avatar
papapete
I want to let you know and thank you! I replaced my ICM last night drove it to work today! Still acting a little strange but I think it's a timing issue will do some fine tuning and see where I'm at. Will keep you posted. Any other thoughts? Thanks again
Old Aug 2, 2013 | 10:40 AM
papapete's Avatar
papapete
One more thing...my car is all original carb diss 02sensor etc etc should I have the carb rebuilt?? The cats have bein removed. Replaced with stainless all else is original
Old Aug 2, 2013 | 02:05 PM
7T1vette's Avatar
7T1vette
Timing on the '81 is set 'differently' because of the computer-control system. Check the internet for instructions on setting timing on '81 C3. You just have to disconnect some connector, if I remember correctly.
Old Aug 2, 2013 | 03:22 PM
SGAL1's Avatar
SGAL1
Old Aug 2, 2013 | 04:02 PM
commander_47's Avatar
commander_47
Just another good reason to trash the ecm carb and dist.
Old Aug 2, 2013 | 05:05 PM
7T1vette's Avatar
7T1vette
And that advice is about as good as your financial advisor suggesting that you should invest in bonds, now....
Old Aug 2, 2013 | 07:48 PM
commander_47
Well, if flushing money down the drain trying to keep bad performing equipment that ran badly in the first place is your idea of a good investment.....have at it.
I'd rather invest in something trouble free with a great deal more performance. Not to mention looking better.
Old Aug 2, 2013 | 08:54 PM
Shark Racer
A well set up E4ME Quadrajet will have EXCELLENT throttle response. Fuel economy will exceed any other 4 barrel carb on the same motor.
To Performance Problems on 81
Old Aug 2, 2013 | 10:23 PM
qwank's Avatar
qwank
i'll put my car up against any comparable L-48 any day
Old Aug 3, 2013 | 05:38 AM
7T1vette's Avatar
7T1vette
Individual negative stigmas about an engine type that you've [probably] never had does nothing to help the OP.
There is nothing 'wrong' with a working '81 powertrain system. The (electronic) fuel mixture module in the carb is readily available, as is the ECM. All components can be rebuilt or replaced for relatively small $$$, compared to buying all-new engine components. When working, the system has adequate power, good economy, and excellent start/idle/run qualities.....unless you just want to race the he!! out of it.
Old Aug 3, 2013 | 08:04 AM
commander_47
Again, I HAVE an 81. I ran it stock for a long time. Got tired of the CCC issues and that economical nightmare called a q junk.
If constant diagnosing of the q junk, computer and assorted other add on components is your idea of fun, have at it.
A stock 81 is like driving a Vega that looks good. And the gas mileage is no better than any well tuned small block.
It doesn't take much to clean up the engine compartment, trash the junk and have a nice car.
You also don't have to build it to race. Just something that won't be embarrassed by all the Kia's and Hyundai's out there.
