Supercharged 383 Engine Installation Progress
Old Aug 11, 2013 | 12:03 PM
bluedawg's Avatar
bluedawg
Nice. Thanks for sharing.
Old Aug 11, 2013 | 03:44 PM
lars's Avatar
lars
Radiator is in, and everything is now hooked up less the coolant hoses and the completion of the electrical system:
Old Aug 12, 2013 | 06:11 AM
diehrd's Avatar
diehrd
That is pretty sweet , you are killing me lol . I ..........need ......... suupercharger
Old Aug 12, 2013 | 07:33 AM
minitech's Avatar
minitech
Would be nice to put one more tube on that to pull fresh air from in the fender/outside and not in the hot engine compartment. But very nice!!
Old Aug 12, 2013 | 10:45 PM
lars's Avatar
lars
Actually, we've been talking about doing exactly that. Once we get the car on the road, we're going to take a look at the "phase 2" refinement upgrades, which will include a cold air inlet system pulling cool air from the inside fender area.
Lars
Old Aug 13, 2013 | 08:13 AM
minitech's Avatar
minitech
Lars
It would be cool to do this experiment: Leave it as it is and drive it for a couple hours on the road. Put it on the dyno, keep the hood closed as much as possible and do some pulls with the 250 - 300 + degree air right next to the headers going in. Then do the same thing with air from the outside. Just to show there is a difference. Nice set up to get some comparative dynos for that.
Old Aug 13, 2013 | 10:01 AM
GRipp 73's Avatar
GRipp 73
If you are too busy and need someone to drive it around for a couple of hours before doing the pull I would be happy to volunteer my services
Old Aug 16, 2013 | 03:39 PM
lars's Avatar
lars
That's certainly a generous offer, but I wouldn't want anyone to be inconvenienced by my need for a test driver...
Here's the latest progress on electrical control system: Since there's no good space for mounting an MSD, fuel pump relay, accessory fuse box, and circuit breaker in the engine compartment of a C3, I have fabricated a simple electrical panel that bolts in place right on the passenger side inner fender well. This panel mounts the MSD, the boost retard switch, the fuel pump relay, the accessory fuse block, and the accessory circuit breaker for all this. This removable panel controls the fuel pump through the oil pressure switch, and the ignition system, all without any draw on the stock fuseblock other than an "IGN" trip wire through the new fuseblock relay. Nothing is spliced into the stock wire harness, and this panel takes care of all electrical requirements for the current and future accessories. It will all be hooked up with quick disconnects, so the entire panel can be removed and serviced with 3 screws:
Lars
Old Aug 16, 2013 | 04:34 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Don't forget the little seal washer under the aircleaners wingnut.
Old Aug 16, 2013 | 05:41 PM
lars's Avatar
lars
Oh, crap..!! I almost forgot that.!! That would not only allow major debris to enter the engine, but it would result in a MASSIVE boost leak, with associate HUGE drop in power. I'm so glad you caught that - you can, obviously, see in the above photos that the washer is missing...
With that fixed, I now also have the electrical system panel mounted. It actually works, and the engine fired up on the first crank, thanks to the wingnut seal washer:
Old Aug 16, 2013 | 06:05 PM
BlackC3vette's Avatar
BlackC3vette
With the additional electronics, what output is the alternator rated at?
Old Aug 16, 2013 | 11:11 PM
lars's Avatar
lars
The additional electronics are the fuel pump (with its control systems) and the MSD ignition. The pump runs at 6 amps, and the MSD draws less than 1 amp per 1000 rpm. That puts the new panel draw at about 12 amps, so the stock alternator is likely to handle it. The primary purpose of the panel is to provide clean, circuit-protected ignition-triggered power and battery power without the need to hack into the stock wiring system, and to get all the control components mounted in a single accessible location.
Lars
Old Aug 17, 2013 | 12:07 AM
  #33
BlackC3vette
Lars
OK, so all that is needed is a stock alternator to go with the "LSC" - LarsSuperCharger kit.
Old Aug 17, 2013 | 10:00 AM
  #34
lars's Avatar
lars
That's the way the ad will read...
Old Aug 17, 2013 | 11:15 AM
  #35
CA-Legal-Vette's Avatar
CA-Legal-Vette
You could always mount a second alternator
A serious question about the fuel pressure. I understand the need for having the input fuel pressure to be higher than the boost pressure but won't this cause the float valves to leak? Is there a margin on these or can you raise the sealing pressure by altering the float level?
Old Aug 17, 2013 | 09:44 PM
  #36
diehrd's Avatar
diehrd
Lars ,, any chance you can post up a video of this thing on the road once it is done ?
Old Aug 17, 2013 | 10:27 PM
  #37
cardo0's Avatar
cardo0
The distributor is an aftermarket HEI that I've put an aggressive mechanical curve in. It's also running vacuum advance to get the idle smoothed out and to assure cool running in city traffic. It's set up to produce 34 degrees total timing at 2500 rpm with 18 degrees initial. The vacuum advance pulls in an additional 14 degrees, making the engine idle at 32 degrees of timing. Under boost, the vacuum advance drops out, of course, and the ignition is controlled through a boost-controlled MSD system which retards the timing with each pound of boost (there is actually a vacuum hose hooked up to the MSD box, which senses manifold pressure). We did a lot of dyno pulls to optimize the boost retard, thinking that best power would be produced by not retarding the timing. Even though we did not get into any detonation by leaving the full 34-degree timing curve in it, we dialed in some retard to see what the numbers would do: Setting up the MSD for maximum boost retard surprised us by producing about 25 horsepower more with no other changes to boost or parameters.
Lars
So i'm reading the MSD box is setup for max boost retard from 34* mechanical. Curious what retard/advance u have at full boost/rpm?
Also when do u see/have boost come on? 1000rpm? 1500rpm?
One more question, how's that 4-speed muncie? Any mods for that kind'a power?
cardo0
To Supercharged 383 Engine Installation Progress
Old Aug 18, 2013 | 01:26 PM
  #38
lars's Avatar
lars
On a blow-through application, the float bowl is pressurized. The needle/seat sees differential pressure between the fuel inlet and the pressure in the float bowl. So if the fuel pressure is 7 psi, and the float bowl is pressurized at 7 psi, the needle/seat sees -0- pressure. The needle/seat only "sees" the pressure differential between inlet pressure and pressure above the seat. So even though the fuel pump is putting out 15 psi under 8 pounds of boost, the needle/seat only "sees" 7 psi.
I was wondering the same thing, but I was too chicken to stand right by the harmonic balancer at 6000 rpm and 8.5 pounds of boost with a timing light... All I know is that we tried all kinds of different combinations with mechanical total timing and boost retard positions, and this "max retard" position with 34 total produced best power and torque under all conditions.
The blower is actually producing boost at idle, and it's blowing off through the blowoff valve - the blowoff is about like a hairdryer on the "hi" setting with the engine just idling. This thing instantly pressurizes the manifold the moment you go to WOT and force the blowoff valve to close. It's just a couple of pounds at low rpm, and then it comes on very quickly.
The 4-speed Muncie is fine. It's in the basement, and does just fine in the dark. I put a Tremec 5-speed in the car...
Lars
Old Aug 18, 2013 | 03:57 PM
  #39
cardo0's Avatar
cardo0
Lars
Wow, dumping boost at idle. How does the blowoff valve change settings to prevent overboost at high rpm? Sounds like your running boost for a "normalized" pressure like GA piston aircraft turbo.
Okay a 5 speed Tremec sounds like a better match for the vortec type blowers. I read the vortec blowers like to stay in the hi rpm and not a good match for something like a 3 speed auto. But if running "normalized" shouldn't be much problem. Whatch'a think lars, could u run an auto behind a vortec blower? Can u normalize a blower?
cardo0
Old Aug 18, 2013 | 06:45 PM
  #40
AboveTheLogic's Avatar
AboveTheLogic
Originally Posted by qwank
i hate spiders. If I saw those in my car, i'd never drive it again
my '78 was infested with some mean lookin' solid black spiders when i bought it. nests and all!
i power washed every inch of the underside and used enough cy-kick that i probably should have called in hazmat
