Front suspension question
Old Aug 9, 2013 | 05:38 PM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
Default Front suspension question
I am preparing to rebuild the front steering/suspension on my '80. I can get a kit from a friend that has all the bushings, ball joints, tie rod ends, etc. that fits a '66 very reasonably. What is the difference between the two? I thought that suspension parts were very common up through the early '80 models.
Old Aug 9, 2013 | 05:44 PM
'75's Avatar
'75
I just looked at Zip and 63-82 takes the same kit.
Old Aug 9, 2013 | 05:45 PM
CaseyJones's Avatar
CaseyJones
I just did the same thing... duh to me.
Thanks!
Old Aug 9, 2013 | 05:52 PM
TWINRAY's Avatar
TWINRAY
You did'nt ask but I will tell you anyway - I don't like "no-name" kit type front end parts. And make sure you use poly ball joint and tie rod end boots. That's all
Old Aug 9, 2013 | 06:33 PM
gcusmano74's Avatar
gcusmano74
Only difference is that 63-64s are drum brakes, and 65-67s have small front wheel bearings. The C3's came with a slightly larger, stronger unit.
The rest is the same until 1982.
But ain't that a crime? That Chevrolet wouldn't change anything for so many years?
No wonder GM needed a bailout. They had more than a 50 year head start on the Japanese auto makers and let them catch up.
Old Aug 9, 2013 | 10:19 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
IIRC the front spindle/bearing size changed over in '69.
Old Aug 10, 2013 | 08:57 AM
gcusmano74's Avatar
gcusmano74
Yeah, you're right. My bad.
Old Aug 10, 2013 | 01:45 PM
redvetracr's Avatar
redvetracr
beware of buying a kit, there is a lot of cheap Chinese crap out there.
Old Aug 11, 2013 | 10:02 AM
cottoneg's Avatar
cottoneg
Moog has worked for me. Special items if you have a specific need.
Old Aug 12, 2013 | 11:39 AM
TWINRAY's Avatar
TWINRAY
and great customer service unlike another company that starts with the letter Raybestos.
Old Aug 12, 2013 | 12:33 PM
Diablo427's Avatar
Diablo427
:rof l: Thanks for that! I read it and started actually laughing out loud.
Old Aug 12, 2013 | 03:49 PM
7T1vette's Avatar
7T1vette
Don't buy 'bargain' kits when purchasing items for the safety related components in your car. Buy brand name parts that you have confidence in. Your "peace of mind" is worth more than the cost difference in such situations.
Old Aug 12, 2013 | 07:22 PM
qwank's Avatar
qwank
willcox sells a kit with all made in USA components. that's what i used on my car and i am more than happy with the results
Old Aug 13, 2013 | 10:52 AM
Teem66's Avatar
Teem66
1980 L48 Auto
Sorry to butt in but can someone suggest a good video or post for rebuilding the C3 front end. I can do a search but I'd like the opinion of someone who has actually done the job.
Thanks.
Old Aug 13, 2013 | 11:47 AM
Rally68's Avatar
Rally68
Originally Posted by Teem66
1980 L48 Auto
Thanks.
This is the best & most concise "how-to" that I have read (unfortunately I read it after I did mine!) It references C2s, but they are exactly the same.
http://www.corvettefaq.com/c3/HowtoRebuildFrontEnd.doc
There are several good threads with pictures on here, use the search function. Ditto for rebuilding the steering box and power steering valve, if those projects will be part of your front end project.
Good luck!
Old Aug 13, 2013 | 12:50 PM
Teem66's Avatar
Teem66
Exactly what I was looking for.
To Front suspension question
