DynoMax install question
Old Jun 29, 2002 | 06:55 PM
rainman69's Avatar
rainman69
Default DynoMax install question
Alright, I have my DynoMax headers installed...how do I get this stinkin' alternator bracket to work? Anyone have pictures or directions? I've figured out how it mounts to the header bolts, but the lower alternator bracket that bolts to it (stock bracket, the funny shaped one) does not bot up to it properly...
Help???
Old Jun 29, 2002 | 09:48 PM
tworottiedogs's Avatar
tworottiedogs
Default Re: DynoMax install question (rainman69)
I made a spacer and used a stud for that bolt. Mine still doesn't line up perfectly but it is close.
Old Jun 29, 2002 | 10:11 PM
rainman69's Avatar
rainman69
Default Re: DynoMax install question (tworottiedogs)
Mine's not really even close...
Old Jun 30, 2002 | 11:42 AM
Jason Staley's Avatar
Jason Staley
Cruise-In III Veteran
You could put a later model alt. bracket on your car. I have a 76 and its alt. bracket is two pieces. The pivot mount bolts to the two holes in the front of the cylinder head. The adjuster bracket bolts to a stud on the water pump. With this setup nothing bolts to the dynomax headers, thus no problems. :D :D :D
http://temp.corvetteforum.net/c3/greatwhite/
Old Jun 30, 2002 | 02:29 PM
rainman69's Avatar
rainman69
Default Re: DynoMax install question (Jason Staley)
Like this one for sale on eBay?
Old Jun 30, 2002 | 11:09 PM
Aaron-74's Avatar
Aaron-74
Here's mine...
Old Jun 30, 2002 | 11:10 PM
Aaron-74's Avatar
Aaron-74
That's the one I've got..It clears everything.
Old Jul 1, 2002 | 09:20 AM
rainman69's Avatar
rainman69
Default Re: DynoMax install question (Aaron-74)
What size/length bolts does it take to bolt to the head and to the alternator?
Old Jul 1, 2002 | 05:32 PM
Aaron-74's Avatar
Aaron-74
I've got two 9/16' 1inch long SS bolts holding it onto the head. And the bolt that came with the alt. is working fine holding it tight to the belt.
Old Jul 1, 2002 | 08:02 PM
jackson's Avatar
jackson
I have one that looks just like pictured on Aaron-74's motor. Mine is cast iron, has GM casting number 3951337 ... mine supposedly came off a pick up truck! It's going on my 71 cuz it had a flimsy stamped steel thing (GM factory) that also bolted onto the drivers exhaust manifold. As mentioned, the iron mount does not bolt to the manifold nor header. I understand that GM made some of these in cast aluminum ... maybe on some late sharks. Either way, should work as long as there are accessory mount holes in driver side head.
JACKSON
To DynoMax install question
