Body Dollie Constuction Question.
Old Aug 20, 2013 | 10:49 PM
Maymyvetteliveforevr's Avatar
Default Body Dollie Constuction Question.
The photo below is the body dollie for the C2 are the dimensions exactly the same for the C3? Are there any changes you would make as I'm going to starting building it Thursday.
[/QUOTE]
Old Aug 21, 2013 | 12:35 AM
boat196's Avatar
boat196
http://www.lbfun.com/warehouse/tech_...dy%20Dolly.pdf I used this dolly for a 1970, it worked out great.
Bob
Old Aug 21, 2013 | 06:26 AM
Jig A Low's Avatar
Jig A Low
I build that same dolly for my '81, it worked OK but you will have to make some mods for it to fit right, the dimensions are correct, but I had to add a couple of 2x6 standing on their sides down the 53" "sides" of the main body portion of it. also, you will need some kind of support for the nose of the body when it's on the dolly, I used a couple 2x4's mounted diagonally from the dolly towards the nose and was able to get them wedged up between the opening for the hood and where the headlight mechanisms mount to the body. it works but you will have to do some "jury rigging" to make it fit your specific application. I would also build it taller if you plan on working on the bottom of the body while it's on the dolly.
Old Aug 21, 2013 | 07:52 AM
Alan 71's Avatar
Alan 71
Hi mmvlfe,
I think that's a very good dolly.
One of the things I learned when I investigating building a dolly is that it's useful to have the body supported at just the 8 body mount points. This allows you to have access to the large percentage of the underbody for whatever work you'll be doing.
I took the body mount locations and heights off the frame drawing in the front of the Chassis service manual.
The dolly I built isn't as strong as the one you picture but is fine for 1 or 2 restorations. The large wheels make it easier to move the body around, especially if it's outside.
The materials can be bought and the dolly built in 1 morning.
Good Luck!
Regards,
Alan
Old Aug 21, 2013 | 08:46 AM
Bob
Thanks for the reply although for some reason the link doesn't work. Are you saying you didn't have to mod the dollie that I've shown?
, Thanks for the reply, I've read in other posts that the dollie is actually strong, you found that not to be true and recomend more strength?
Originally Posted by Alan 71
Hi mmvlfe,
Thanks for the reply Alan, I like that design although I'm going to need to replace the two rear mounts and clean up the other 6, therefore if the dollie rest on the mounts that limits my access.
Old Aug 21, 2013 | 10:17 AM
Dega500's Avatar
Dega500
Correct me if I'm wrong but it looks to me like you could just add an equal amount to every vertical support post to get your desired work height. Then with these vertical posts mounted this way couldn't you simply remove the one at the mount you were working on. It could still be supported by the seven other mounts at all times.
If I'm missing something, sorry for the confusion. Still trying to get the nerve to do this to my 80!
Old Aug 21, 2013 | 12:20 PM
lars's Avatar
lars
The wooden structure dolly you have a drawing of seemed too cluttered and low to do bottom-side work, so I built a simple tube frame structure that’s a bit taller. This allowed me to easily work on the bottom of the body while still having the sides and top fender surfaces at a good working height for block sanding. I used the wooden dolly drawing for some basic dimensions, and verified those dimensions against the body mount locations on the car before welding up the structure. This structure is very open on the bottom, allowing me to sit on a roll-around stool and comfortably work on the bottom of the car.
Here’s the body being lowered onto the tube dolly. The entire dolly was built in an afternoon with a cutoff saw and a MIG welder:
Dolly held the body rigid enough that the doors could be opened and aligned:
The dolly was the perfect height for sanding and body work: I didn’t want to have to be bent over too far while sanding the lower sides of the body:
The body was even transported while on the dolly – I was able to roll the entire thing up on my trailer and chain it down for transport:
Lars
Old Aug 21, 2013 | 05:03 PM
Alan 71's Avatar
Alan 71
Hi mmmvlfe,
The uprights on the dolly I show are held in place with 2 bolts so they can be removed 1 or 2 at a time thus you have access to the mounts.
Regards,
Alan
A steel dolly is the way to go... but a few people aren't welders.
Old Aug 21, 2013 | 05:29 PM
Ibanez540r's Avatar
Ibanez540r
^ I built a dolly on Alan's plans. I added two more cross-beams on the other side of the 4x4s just to beef it up a bit. Works great, car is sitting on it right now in the garage.
Old Feb 22, 2014 | 10:36 AM
GregS_72's Avatar
GregS_72
From: St Louis MO http://1972corvetterestomod.blogspot.com/
Hi mmvlfe,
Good Luck!
Regards,
Alan
Hello Alan,
I really like this idea... supporting the body at the mount locations, also plan to support the nose. Worried about the body possibly wanting to sliding off those vertical uprights. How did you guard against that? Based on your experience, what do you think about running a 2x3 across the top of each vertical upright pair that it is a little longer than necessary to give the body room to slide horizontally? Would that work... ie. no protrusions on the body underside that would now rest on these horizontals and thus not be on the uprights at the mount locations?
Thanks!
Greg
(also sent you a PM a bit ago when I found your plans in a different thread, but the forum system wouldn't let me quote it with your pics as it was forwarded from someone else)
Old Feb 22, 2014 | 11:27 AM
Alan 71's Avatar
Alan 71
Hi Greg,
If you look carefully at the photo you can see one of the two uprights supporting the nose of the body.
They're not on the plan because I didn't add them until I actually transported the body on the dolly.
I didn't feel as though the body wanted to move around on the dolly. But it would be VERY easy to put a lag screw down through the #1 mount on each side. Since you'd be screwing into the end of the upright I'd drill a suitable size hole first so you don't split the upright.
Regards,
Alan
It's difficult for me to believe that this picture is 10 years old!
Old Feb 22, 2014 | 11:58 AM
GregS_72's Avatar
GregS_72
Thanks Alan, great pic too. Did the 2x3's work ok for you? In hindsight would you have preferred 4X4s for the larger surface area?
Old Feb 22, 2014 | 03:19 PM
Alan 71's Avatar
Alan 71
Hi MS,
The smaller size seemed to work fine. I really don't see any reason to not use a 2x4 though.
Regards,
Alan
In my case the most important thing was the large wheels. This made it really easy to move around. Which was important since the fellow who painted the body works by himself and he would push it out in the sun everyday during the late spring, summer, and fall.
Old Feb 22, 2014 | 03:59 PM
GregS_72's Avatar
GregS_72
Thanks Alan. Think I'm going to go the 4x4 route for the uprights with lag screws out the top for peace of mind. Hopefully in a few weeks I can post pics of the body resting on the dolly.
Old Feb 22, 2014 | 04:28 PM
Alan 71's Avatar
Alan 71
Hi,
If you do use the 4x4 you'll need to change the dimension on the width of the dolly frame so that the center + of the 4x4 is the center+ of the hole for the body mount bolt.
Regards,
Alan
Old Feb 22, 2014 | 04:31 PM
GregS_72's Avatar
GregS_72
got it, thanks
Old Apr 19, 2014 | 02:07 PM
GregS_72's Avatar
GregS_72
This dolly worked great for me. See below for a couple pics. I decided to stick with 2 x 3's for the uprights, but did make a few minor adjustments...
            Overall, Alan71's plans are great... Thanks Alan! If you don't mind, I'm going to link to this post in a restoration blog I'm starting and give credit where credit is due! Here's a link to the blog.... http://1972corvetterestomod.blogspot.com/
            Old Apr 19, 2014 | 04:18 PM
            Alan 71's Avatar
            Alan 71
            Hi MS,
            The improvements sound good.
            Having the larger wheels does make moving the body around easier.
            Once my body was pretty much ready to paint the fellow who painted it pushed it out into the sun each day from about May to October. The bigger wheels made it easier for him to maneuver it by himself
            Good Luck!
            Regards,
            Alan
            To Body Dollie Constuction Question.
