Reelav8r,
My motor isn't finished yet. Stupid stuff keeps gettin' in the way! Like weddings (not mine), Carlisle, trips out west (OK/TX/LA), and on and on. Plus, my bud helping me on the build has moved several hours away, and can only get out here every other week. I hope to get it to the dyno and in the car before I die.
Carter
Ok, so no long term results that I can find. Guess I'll be a guinea pig.
Cuisinartvette has a few hundred hard miles on his (7k + rpm) and no wear at all. At least that's better than the bronze tip. This fuel pump failure may have saved my bacon down the road as I had not heard of them mushrooming before this. My main concern was the cam.
maybe a simple phone call to Lunati would clear it up
This from the guy who followed the guidance from cam manufacturer and still got shafted? Seriously though , you're right it doesn't hurt to ask the manufacturer of the components involved. I just keep in mind they don't give a hoot what the out come of their component is or how much trouble and time it costs me as long as it's out side the scope of their warranty.
I already did call Lunati. Got the answer from them. Also called Howards today. The tech I talked to claimed to have the carbon polymer push rod in his car and had been running it for 10,000+ miles.
When I was preparing to install my Comp Retro Roller cam kit, I was informed that the cam is iron; not steel. Therefore, I did not have to go with a special distributor gear or fuel pump pushrod. I had purchased both and dropped nearly $150.
I did install a new fuel pump pushrod as my solid steel OEM unit had some scarring on the tip; it was original from 1980. The replacement is hollow with an iron tip/insert.
I would verify the roller cam you installed requires a special bronze tip pushrod. I would have installed my bronze tipped pushrod and plastic dizzy gear had I not gotten the advice from a forum member. I just assumed the cam was steel like most roller cams.
Royal Canadian Navy
TedH, I went with the poly type because it will work with any type of cam material, so it's advertised. I would like to go with a solid roller billet cam some time in the future so now I won't need to purchase these parts again provided they hold up.
Well two things I have not been racing my vette. so i lowered the rev limiter to 7000 and I do mostly performance street driving and trips. I have something over 5000 miles on the poly gear
Do you have the austempered ductile iron cam? It's my understanding that you need the melonized dist. gear for that unless they pressed on an iron gear. And if running high volume or press fuel pump you still need different fuel pump push rod.
Royal Canadian Navy
That sounds somewhat reassuring considering the mileage is over 5000. Have you had the dist'r out and taken a good look at the gear?
Yes, a couple of months ago I popped the head gasket. So I put on my spare AFR 210 heads that I had laying around. The poly gear looked new.
Comp Cams claimed that my high oil pressure was the problem. I countered that it was them that screwed me and delivered a non-sleeved cam that I had ordered.
If you look at the gear picture..... It might have been a bit low in it's contact to the cam gear. So along with lighter oil weight I also shimmed the dizzy higher on the manifold to ensure full contact gear meshing. Or it could have had a flaw when it was molded. I think it had 2-3 months on it when it broke.
My Comp Retro-Roller Xtreme Energy cam kit ends in '-8' (cast iron). I am advised that the stock distributor gear works fine with the cast iron cam.
IMO, the manufacturers and sellers of these kits need to get their collective stories straight on the parts that are required; not just recommended (ie. composite gear recommended to avoid issues if cast iron roller gets replaced with steel roller sometime in future...).
I installed the Comp steel tip pushrod #4616 for use with my cast iron retro roller cam.
Why are you guys saying poly over cast iron? There IS a third option.
Cast is harder than steel. Plastic is softer than steel. Bronze is ALSO softer than steel. I have been running my bronze gear on my steel billet roller cam for 12 years. Still running and timing is smooth! ;-) There are other ways to insure that gear lasts longer. If you're block is .005 decked or tighter shim the height and make sure the pump shaft isn't binding. Don't run herky jerky gear drives. They beat valvetrain components to death, make sure.you timing chain is good & tight and it's not loading and unloading. Running a cam button and controlling the forward movement of the camshaft? They can move a LOT. THERE'S 50-80LBS (POSSIBLY) pushing that cam forward. As rpm changed, timing changes, oil pressure changed, heavy braking... all slopping that cam back and fourth.
I am running the carbon polymer in our 13:1 384.57 circle track engine.... going to find out in April if it'll hold ;-)
I have the hollow bronze tipped light rod for the old engine.... it's wear seems very strange. It was on one side of the tip. Thinking the fuel pump end by the marks.. guess well find out PDQ of it's worth the 45.00. At 7200 rpm 2 nights a week for the entire summer;-)
Still kinda valid info though for those using the search function to research for their answers like many do.. I belong to about 7 different forums and this is one is different than most in this regard... In many forums you see people scolding others to use the search function rather than starting new threads on old topics. Also the "related topic" threads seem to promote rehashing old threads...
It also would be cool if anyone had any updates from long term use with these composite rods since I just bought the bronze one im now apprehensive about using since I stumbled on this.
Royal Canadian Navy
Originally Posted by resdoggie
That's what I'm using also. Just a few hundred miles on my hyd retro roller but no problem so far.
Edit: I also use a Howard's composite distributor gear, fwiw.
I have not had any issues with my composite dist gear and fuel pump push rod. Going on 8 years now.
A high volume sbc pump adds 3 horsepower drag on any distributor gear over a std volume, just FYI. We back to back tested this in 07' on Solid Roller 383 that made 560 horsepower.
Royal Canadian Navy
Just for info, I have a Melling oil pump, hv/hp, but I have used the low pressure spring since I installed the pump 25 years ago. No visible wear on the composite dist'r gear. I haven't seen my composite fuel pump rod in a long, long time.
