I have a new re-built engine and the fuel pump decided to quit. Got it all apart and noticed that the bronze tipped fuel pump push rod has some signs of wear on it. The face that rides on the cam lobe is no longer perfectly flat.
Is the fuel pump push rod supposed to rotate in it's bore like a flat tappet cam lifter?
Should I expect to see some wear on this bronze tipped push rod? The engine has only been in service for a few hundred miles. I'm wondering how it will look after a few thousand.
The reason for the bronze tip is this is a Lunati retro roller cam set up.
I also checked to see if the fuel pump cam lobe had gone flat. The pushrod only moves in and out about 1/2 inch or so. Does that sound about right?
When I took apart my 434 SBC I had a heck of a time getting the what was left of a bronze tipped fuel pump rod out of the block. It was nearly warn away and kind of mushroomed so it would not come out of the block. Once I had the motor torn down on a stand I had to emery cloth sand away the mushroomed head to get it to come out.
Bronze tips are kind of a POS and I bought the roller for the new refresh.
That sucks. Were you using some kind of high capacity or pressure fuel pump that would require more force to pump fuel?
I really don't want to have to shell out the cash for a roller tip push rod and I sure don't want the current one to mushroom to the point that it can't come out then I'm SOL for replacing it until the engine gets torn down. What to do......?
Are you sure you need a bronze tip? I have a Crower retro roller that uses the stock fuel pushrod.
Pretty sure that is what Lunati told me when I asked. It was a while back. Maybe I'll give them a call and ask just to make sure. Also had to get the melonized dist gear.
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
"Ultra Lite billet fuel pump pushrods weigh only 0.9 oz. (27 grams) to eliminate fuel pump cavitation. Gentle on the cam lobe,"
Seems to me the pressure on the cam lobe would come from the pressure of the spring inside the fuel pumps, saving a gram or two in the push-rod itself ain't gonna do squat.
I have the Comp Cams roller tip and it has lived in my car for 8 or so years with RPM's up to 7000. Been checked twice, the last time this summer and it looks and rolls like it was brand new. I would endorse this product
Decided on the Howard's carbon polymer push rod from summit. Should be here by wed. If the fuel pump was easier to get to I'd put it together today with new pump so I could do some tuning. Guess I'll wait though given the PITA access to it.
Do you mean will they shorten from wear over time? I have no idea. Will they mushroom like a bronze tipped one? I doubt it. I'm using a standard fuel pump so pressure on the rod is not high vs a high flow or pressure pump.
Maybe cuisinartvette could tell us how many miles he has on his and if he's had any issues.
I am skeptical when it said NASCAR. They only make things for a 600 mile motors.
Comp Cams sent me a non sleeved billet SR cam after a month of waiting. Then they said I needed the poly Dizzy gear which they air mailed the next day out.
The bummer was race weekend with 80 psi shifting from 4-5 at 140 mph on the main straight The motor went silent. So I stabbed in the clutch and tried to hit the key ............... I coasted off a fire exit dead. The poly gears had lost some teeth....... No spark or oil pressure and my race day was done
I can see why you might question it. You have a valid point the word "nascar" also concerns me a little since it sounds like hype to sell something new.
In your case with the gear the component was in shear vs a push rod which will be in compression. So not necessarily apples to apples.
Thanks for the report resdoggie more than a couple hundred, maybe a few thousand would be a better test of durability.
