fuel pump push rod questions
Old Jan 21, 2021 | 10:21 AM
  #41
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Originally Posted by resdoggie
Just for info, I have a Melling oil pump, hv/hp, but I have used the low pressure spring since I installed the pump 25 years ago. No visible wear on the composite dist'r gear. I haven't seen my composite fuel pump rod in a long, long time.
Spring makes all of the difference.....we tested the Moroso pre-made pickup/pump out of the box bolt on for both tests in the same pan.
Jebby
