Diff Plug Leak
Old Aug 26, 2013 | 07:01 PM
Stoge's Avatar
Stoge
Default Diff Plug Leak
I noticed a drip on the floor under my '79's rear end so out came the jack stands and flashlight today.
Diff is leaking from the drain plug. I sent the diff, t/a's & halfshafts off to VanSteel for a rebuild a couple of winters ago and they did an outstanding job. I failed to mention the leak from the drain plug before sending the parts in thinking they would magically know to fix the problem. So, what can I do about this? Put an O-ring on the drain plug? Teflon tape? New plug? Should I remove the limited slip diff lube tag from the plug?
Old Aug 26, 2013 | 08:54 PM
flyeri's Avatar
flyeri
I used thread sealant. I think I got it at Advance Auto. Don't put it on the first few threads. Worked great on mine.
Old Aug 26, 2013 | 09:03 PM
DAVID SLUDER's Avatar
DAVID SLUDER
I had the same problem, I put teflon tape on mine, and no more leaks
Old Aug 26, 2013 | 10:50 PM
gcusmano74's Avatar
gcusmano74
Yes. And the teflon tape will make it easier to remove the plug, next time.
Old Aug 27, 2013 | 01:23 AM
Stoge's Avatar
Stoge
Thanks for the replies. I'm glad the usual suspects - Teflon tape and thread sealant - will work.
To Diff Plug Leak
